Modified HK FPV platform
3689426823?profile=original
I made following modifications
wing span increased to 74 in
root cord 12inch
Tip cord 9inch
Tested with 2x8000mah Tenergy pack
got 1hr endurance
Di-hedral 4inch from wing tip
IT is very hard to turn from aileron will reduce the di-hedral to 2inch
Prop apc 1407E will test 1412E
Takeoff weight was 4000grams
  •  I like how you extended the motor mount for a bigger prop, have you got a close up picture that shows more detail of that motor mount? Which HK model did you start with?
  • do you handlauch this? or bungee?
