More powerful Pixhawk 3 coming soon
3689714598?profile=original
The PX4/Dronecode team and Drotek have been working on the next generation of Pixhawk autopilots, and you can now see a preview of that with the Pixhawk 3 Pro. It's based on the new PX4 FMU4 Pro standard, which includes a full suite of next-generation sensors and and the more powerful STM32F469 processor. It's designed for the Dronecode/PX4 flight software, which is the current official Pixhawk standard.
The board is currently in developer release, but will be taken out of beta after testing is complete in the next month or two.
All details are here (and below):
Introduction
FMUv4-PRO takes input from all of the Pixhawk stakeholders; end users, developers, researchers and manufacturing partners. Goals for this iteration of the platform are:
  • – An integrated, single-board flight controller for space constrained applications
  • – A modular multi-board flight controller for professional applications
  • – Sufficient I/O for most applications without expansion.
  • – Improved ease-of-use.
  • – Improved sensor performance
  • – Improved microcontroller resources (384 KB RAM, 2 MB flash).
  • – Increased reliability and reduced integration complexity.
  • – Reduced BoM and manufacturing costs.
Key design points
  • – All-in-one design with integrated FMU and optional IO and lots of I/O ports.
  • – Improved manufacturability, designed for simpler mounting and case design.
  • – Separate power supplies for FMU and IO (see power architecture section).
  • – Onboard battery backup for FMU and IO SRAM / RTC.
  • – Integration with two standard power bricks.
Technology upgrades
  • – Microcontroller upgrade to STM32F469; flash increases from 1MiB to 2MiB, RAM increases from 256KiB to 384KiB, more peripheral ports.
  • – ICM-20608, MPU9K integrated gyro / accelerometer / magnetometers.
  • – LIS3MDL compass (HMC5983 is now obsolete).
  • – Sensors connected via two SPI buses (one high rate and one low-noise bus)
  • – Two I2C buses
  • – Two CAN buses
  • – Voltage / battery readings from two power modules
  • – FrSky Inverter
  • – JST GH user-friendly connectors
I/O ports
  • – 6-14 PWM servo outputs (8 from IO, 6 from FMU).
  • – R/C inputs for CPPM, Spektrum / DSM and S.Bus.
  • – Analog / PWM RSSI input.
  • – S.Bus servo output.
  • – 6 general purpose serial ports, 2 with full flow control, 1 with separate 1A current limit, 1 with FrSky protocol inverter.
  • – Two I2C ports.
  • – Two external SPI ports (unbuffered, for short cables only).
  • – Two CANBus interfaces.
  • – Analog inputs for voltage / current of two batteries
  • – On-ground usage piezo buzzer driver.
  • – Sensor upgrade connector scheme
  • – High-power RGB LED.
  • – Safety switch / LED.
Mechanical Form Factor
  • – 71 x 49 x 23 mm (with case)
  • – 45g (with case)
  • – Standardized microUSB connector location
  • – Standardized RGB led location
  • – Standardized connector locations
System architecture
FMUv4-PRO continues the PX4FMU+PX4IO architecture from the previous generation, incorporating the two functional blocks in a single physical module.
PWM Outputs
Eight PWM outputs are connected to IO and can be controlled by IO directly via R/C input and onboard mixing even if FMU is not active (failsafe / manual mode). Multiple update rates can be supported on these outputs in three groups; one group of four and two groups of two. PWM signal rates up to 400Hz can be supported.
Six PWM outputs are connected to FMU and feature reduced update latency. These outputs cannot be controlled by IO in failsafe conditions. Multiple update rates can be supported on these outputs in two groups; one group of four and one group of two. PWM signal rates up to 400Hz can be supported.
All PWM outputs are ESD-protected, and they are designed to survive accidental mis-connection of servos without being damaged. The servo drivers are specified to drive a 50pF servo input load over 2m of 26AWG servo cable. PWM outputs can also be configured as individual GPIOs. Note that these are not high-power outputs – the PWM drivers are designed for driving servos and similar logic inputs only, not relays or LEDs.
Peripheral Ports
FMUv4-PRO recommends separate connectors for each of the peripheral ports (with a few exceptions). This avoids the issues many users reported connecting to the 15-pin multi-IO port on the original PX4FMU-PRO and allows single-purpose peripheral cables to be manufactured.
Five serial ports are provided. TELEM 1, 2 and 3 feature full flow control. TELEM4 can be switched into inverted mode by hardware and has no flow control. Serial ports are 3.3V CMOS logic level, 5V tolerant, buffered and ESDprotected.
The SPI ports are not buffered; they should only be used with short cable runs. Signals are 3.3V CMOS logic level, but 5V tolerant.
Two power modules (voltage and current for each module) can be sampled by the main processor.
The RSSI input supports either PWM or analog RSSI. CPPM, S.Bus and DSM/ Spektrum share now a single port and are auto-detected in software.
The CAN ports are standard CANBus; termination for one end of the bus is fixed onboard. .
Sensors
The new ICM-20608 has been positioned by Invensense as higher-end successor of the MPU-6000 series. The software also supports the MPU-9250, which allows a very cost-effective 9D solution.
Data-ready signals from all sensors (except the MS5611, which does not have one) are routed to separate interrupt and timer capture pins on FMU. This will permit precise time-stamping of sensor data.
The two external SPI buses and six associated chip select lines allow to add additional sensors and SPI-interfaced payload as needed.
IMU is isolated from vibrations.
Power Architecture
Key features of the FMUv4-PRO power architecture:
  • – Single, independent 5V supply for the flight controller and peripherals.
  • – Integration with two standard power bricks, including current and voltage sensing.
  • – Low power consumption and heat dissipation.
  • – Power distribution and monitoring for peripheral devices.
  • – Protection against common wiring faults; under/over-voltage protection, overcurrent protection, thermal protection.
  • – Brown-out resilience and detection.
  • – Backup power for IO in the case of FMU power supply failure.
  • – Split digital and analog power domains for FMU and sensors.
FMU and IO Power Supplies
Both FMU and IO operate at 3.3V, and each has its own private dual-channel regulator. In order to address issues seen with PX4v1 and noisy power supply connections, each regulator features a power-on reset output tied to the regulator’s internal power-up and drop-out sequencing.
The second channel of each dual regulator is switchable under software control. For FMU this is used to permit power-cycling the sensors (in case of sensor lockup), and for IO this will make it possible to perform the Spektrum binding sequence.
Power Sources
Power may be supplied to FMUv4-PRO via USB (no peripherals in this mode) or via the power brick ports. Each power source is protected against reverse-polarity connections and back-powering from other sources. Power spikes observed on the servo bus (up to 10V) led to the removal of the power-from-servo option, users wanting this feature can connect the servo rail with a cable containing a Zener diode to the 2nd power brick port.
The FMU + IO power budget is 250mA, including all LEDs and the Piezo buzzer. Peripheral power is limited to 2A total.
Power Brick Port
The brick port is the preferred power source for FMUv4-PRO, and brick power will be always be selected if it is available.
Servo Power
FMUv4-PRO supports both standard (5V) and high-voltage (up to 10V) servo power with some restrictions. IO will accept power from the servo connector up to 10V. This allows IO to fail-over to servo power in all cases if the main power supply is lost or interrupted. FMUv4-PRO and peripherals combined may draw up to 2A total.
Power is never supplied by FMUv4 to servos.
USB Power
Power from USB is supported for software update, testing and development purposes. USB power is supplied to the peripheral ports for testing purposes, however total current consumption must typically be limited to 500mA, including peripherals, to avoid overloading the host USB port.
Multiple Power Sources
When more than one power source is connected, power will be drawn from the highest-priority source with a valid input voltage.
In most cases, FMU should be powered via the power brick or a compatible offboard regulator via the brick port or servo power rail.
In desktop testing scenarios, taking power from USB avoids the need for a BEC or similar servo power source (though servos themselves will still need external power).
Summary
For each of the components listed, the input voltage ranges over which the device can be powered from each input is shown.
Brick ports Servo rail USB port
    FMU 4 – 5.7V no yes
    IO 4 – 5.7V 4 – 10V yes
    Peripherals 4 -5.7V, 2A max 4 – 5.7V, 250mA max yes, 500 mA max
Peripheral Power :
FMUv4-PRO provides power routing, over/under voltage detection and protection, filtering, switching, current-limiting and transient suppression for peripherals.
Power outputs to peripherals feature ESD and EMI filtering, and the power supply protection scheme ensures that no more than 5.5V is presented to peripheral devices. Power is disconnected from the peripherals when the available supply voltage falls below 4V, or rises above approximately 5.7V.
Peripheral power is split into two groups:
  • – TELEM 1 has a private 1A current limit, intended for powering a telemetry radio. This output is separately EMI filtered and draws directly from the USB / Brick inputs. Due to the noise induced by radios powering a radio from this port is not advised.
  • – All other peripherals share a 1A current limit and a single power switch.
Each group is individually switched under software control.
The Spektrum / DSM R/C interface draws power from the same sources as IO, rather than from either of the groups above. This port is switched under software control so that Spektrum / DSM binding can be implemented. Spektrum receivers generally draw ~25mA, and this is factored into the IO power budget. S.Bus and CPPM receivers are supported on this rail as well.
Battery Backup :
Both the FMU and IO microcontrollers feature battery-backed realtime clocks and SRAM. The onboard backup battery has capacity sufficient for the intended use of the clock and SRAM, which is to provide storage to permit orderly recovery from unintended power loss or other causes of in-air restarts. The battery is recharged from the FMU 3.3V rail.
Voltage, Current and Fault Sensing :
The battery voltage and current reported by the power brick can be measured by FMU. In addition, the 5V unregulated supply rail can be measured (to detect brown-out conditions). IO can measure the servo power rail voltage.
Over-current conditions on the peripheral power ports can be detected by the FMU. Hardware lock-out prevents damage due to persistent short-circuits on these ports. The lock-out can be reset by FMU software.
The under/over voltage supervisor for FMU provides an output that is used to hold FMU in reset during brown-out events.
EMI Filtering and Transient Protection :
EMI filtering is provided at key points in the system using high-insertion-loss passthrough filters. These filters are paired with TVS diodes at the peripheral connectors to suppress power transients.
Reverse polarity protection is provided at each of the power inputs.
USB signals are filtered and terminated with a combined termination/TVS array.
Most digital peripheral signals (all PWM outputs, serial ports, I2C port) are driven using feature series blocking resistors to reduce the risk of damage due to transients or accidental mis-connections.
Inputs / Outputs
InputOutput pixhawk pro by Drotek
  • This is not my area of expertise but DJI seem to use IMU heaters and I dare say they have done some research. So I think I would need to see more input on this before I would dismiss IMU heating.
  • Tidbit of info on temperature variation in the sensors: nearly all of the sensors have a temperature sensor. Invensense (now a subsidiary of TDK) has even started adding temperature compensation to their devices. The ICM20602 (pin compatible with the ICM20608G, ICM20609) has temperature compensation registers for each axis. In addition, factory temperature coefficients are pre-loaded, there is a bit to set to enabled/disable correction; kind makes the approach of a "heater" moot. One should not have to heat up the sensor to make it work. The device is rated for -40C to 85C.
    I'd like to know the details of the Pixhawk "not having the infrastructure" to read the sensors adequately...come on guys! We are not dummies here...
    Have a nice flight!
  • Hugues said:
    @Stmpngrnd, Lol, that makes me roll on the floor laughing. This looks absolutely the worst integration idea I've ever seen!
    Taking these images from your site proves my point about how this is a good integration.  Also shows you have a bias in the discussion as you market a product that the cube with a proper carrier board does not need. You should add a CUBE carrier board with your power module integrated to your product line.
  • worst ever...LOL what does a typical DIY setup look like with a power distribution board for up to an X8 config and 3 accessory  voltage regulators?
    It's not huge when you consider what it replaces with MINIMAL wiring!!!!
    You guys crack me up with your crazy demands and expectations (eyes rolling)...guess you want a postage stamp with 21 gigawatts of supercomputer power and wireless power transmission.
    Say what you will but the spaghetti monsters that the PH3 will spawn will be huge messes of wires and components.
  • 100KM
    @Stmpngrnd that looks great, but it's huge!!
  • MR60
  • @hugues  How is this for plug and play? Coming soon from SpektreWorks is a carrier board with power distribution and full i/o connections. How clean of an install would this be? Pretty much bridges the gap between the cleanliness of factory integrated components and the spaghetti wire mess of the typical DIY built copter.
    WS1A0114%28EDITED%29.png?format=2500w&width=400
  • @hugues
    interesting find. However it remains very difficult for many to use such tiny 80 pins connectors. Do you imagine soldering individual pins on that, even as an experienced DIYer ? And if you have to etch your own PCB each time you need an autopilot, we'd be in real trouble.
    Most want something that works (most important), is simple and plug & play.
    That shows the Cube design choice was intended initially for 3DR as a manufacturer of drones with factory plants able to integrate it. Not meant for DIY, not meant for standalone use.
    Last I checked this site was called DIYdrones and not PlugandPlayDrones :-0
    The Cube was designed for maximum flexibility hence the carrier board concept. Don't forget that it is just coming to market with a standard somewhat generic carrier board. More carriers will come not only from Profiicnc but third parties and DIYers as well.
    The Wikki has all the schematics and pcb files. Any DIYer can create any carrier board they want! It's even encouraged hence why Proficnc/Hex lists the connectors in single quantities for us on their site.
    The connector is $4
    Custom designed pcb from OshPark are $5 per square inch for 3 copies
    Hot air solder stations are $50 and reflow methods are easier than traditional soldering by far!!!
    Point is the Cube is as DIY if not more so than anything else claiming to be even though it comes as a standard for plug & play integration.
  • 100KM
    Indeed.Strange strategy indeed.
  • 100KM
    Rob, that's amazing. Where can one get the break out box as in your picture?
