Check out our unique in-flight starter motor for the MVVS 26cc on a custom built Senior Telemaster.
The system is lightweight and robust. Works from a cold start. Works again and again... it is great for extreme long duration flights and vibration free (i.e., no image blur) video or stills while the engine is off. Also, for all those people struggling with gyro drift, you can get a good gyro fix when the engine is off as well.
Cheers from the MotMen UAV team, Newcastle, Australia.
Just as a link, some time ago, but still interesting esp. regarding engine mount: http://diydrones.com/profiles/blogs/scaneagle-video
And the scaneagle carrys cameras, as do other gas powered UAV´s.
Don´t get me wrong, I like the idea you are implementing, I´m just questioning the reasons...
The stealth idea is used in the military drones. Here is one I know of that does: http://www.emt-penzberg.de/index.php?14&L=1 Uses a 2 cylinder 3W motor with folding prop...
Another Idea: Why not use a hybrid propulsion approach? For taking pictures, use a small electric motor with a small battery that is charged by the gas engine that covers the long distances/duration? And you could also sell it as "green" :-)
Alex,
the motor system Maynard Hill developed was increadible. It was the key to the atlantic crossing. Everything else would be obtainable today for a few 100$... There is many interesting reading about TAM and his previous projects on the net! He modified 10cc 4 stroke engines to sparc injection and running on lamp oil. The fuel was controlled by a tricky mechanical mechanism. In the end he got a consumption of 57ml per hour!!! 38h running engine... It was the achievement of a lifetime!
here's the detail. Not sure if you want to tackle all of his methods, but some do look promising.. Like generator instead of battery..
http://www.progressiveengineer.com/profiles/maynardHill.htm
Here's the article Link
I tend to agree with MarcS. While ability to take vibration-free photos is good, stopping-and-starting engine doesn't seem to me the optimal power-consumption scheme.
Unless you intend to use termals as source of power, constant-running engine on it's best-efficiency rpm and carefully chosen prop will allow you to fly longer on cruising speed than iterative start-stop climb-glide pattern.
Prop optimized for high-speed cruise will probably cause problems on take-off but this can be solved in several ways.
1
2
of 2 Next
