My Failed Mini TriCopter
Here's my failed attempt at a mini tricopter design:
More details and pictures on my RobotBox project page. Any suggestions on getting it to work? I can't seem to find any mini RC helis that have props rotating in a direction opposite the ones on there.
Also, I'm looking for more flying robots to be added to RobotBox. It's a little light on aerial stuff :)
  • Davey,
    Thanks for the input. Yeah, I think they were PicoZ's. I've been looking at all the small RC heli's I could find, but they all seem to rotate in the same direction. I'm not sure how much they twin blade heli is, but that's an option. The problem now is that I have to *buy* something, and that always complicates things - it means I actually have to do some planning :)
  • The photo looks like Silverlit Picooz units? They do a twin blade helictoper and I think the units contra rotate but not by gearbox, one of the actual units runs backwards?
    https://www.youtube.com/watch?v=KNxeOa-l6k8
    Regards
    D
  • Maybe because the blades are turning the same direction it might work better if the set up was in a triangle configuration instead of a T configuration. I"m not by far a tricopter guy but seems it might help with what your using. then it would seem controling the speed to each motor would make it go where you want. Just my thoughts.
  • I think you will find that the Shrediquette uses two blades rotating one way and one the other - at least that is the only way I got mine to work. It uses one motor mounted on a pivot whose angle can be varied to give yaw control whereas with a quad you have two pairs of counter rotating blades and speed variation gives yaw control.
    Peter
  • jyro, Good idea. You might be able to notice in some of the pictures that they are slightly titled after someone suggested that to me. Unfortunately, the tilt needs to be variable with thrust, and having an articulating joint will be too complex/heavy for this small design. I also thought about adding baffles under the motors to give side-ways thrust, but you have the same problem.
  • as an alternative to a counter rotating motor you can tilt them to stop the heli from spinning. For instance, shrediquette does it on his tri-rotor copters: shrediquette.blogspot.com/p/shrediquette-dlx.html
