3689598322?profile=original3689598300?profile=originalWe have finished new board NEO-M8N + Compass
NEO-M8N breakout board features:
  • 72-channel u-blox M8 engine GPS/QZSS L1 C/A, GLONASS L10F, BeiDou B1 SBAS L1 C/A: WAAS, EGNOS, MSAS Galileo-ready E1B/C (NEO-M8N)
  • SuperSense Indoor GPS, -167dBm
  • On-board Ultra low noise 3.3V voltage regulator and RF filter for noise blocking
  • USB, I2C (SDA,SCL) and Uart (Tx,Rx)
  • Dual band GPS and Glonass antenna
  • u-center GPS Evaluation Software
  • Extensive visualization and evaluation features
  • Supports AssistNow Online and AssistNow Offline A-GPS services
  • 1 TTL UART port, 1 I2C port,1 USB port
  • Time pulse LED
  • Flash memory for firmware upgrade and settings inside in the module (can save setings without battery)
  • Battery for HOT module start
  • Build-in HMC5883L Compass
  • Dimensions: 50x50 mm hole distance 45x45mm
  • Weight 24 gram
  • Fully assembled and ready to use
  • The M8N is fun. I get 11 sats and 1.0 HDOP in my livingroom, and that's below a metal roof and a reinforced concrete floor.
    But then I removed the NEO module and antenna and replaced a NEO-6 on a GPS that has external SAW and LNA. What do you know, 17 sats and 0.7 HDOP
  • Admin
    @titeuf007,
    Here is the link to the M8 discussion:Link
    TCIII ArduRover2 Developer
  • do you have a link about the m8 discussion thomas?
  • does it possible to have the specific file for arducopter like 3dr ublox file for this gps(with the best tune for it)?
  • Admin
    @Devis,
    The following is from the M8 posts on the drones discussion Group:
    PRT (ports) UART 1
    Protocol out UBX
    Baudrate 38400
    RATE (Rates) Measurement Period 200 ms
    Measurement Frequency 5 Hz
    NAV5 (Navigation 5) Dynamic Model Airborn 4G
    Fix Mode 3 - Auto 2D/3D
    Min SV Elevation 10 Grad
    DGPS Timeout 120 sec
    SBAS
    Subsystem Enabled
    PRN Codes EGNOS (EUROPE)
    120, 124, 126, 131
  • Some can give me the right parameter to use NEO-M8N ( this one http://www.csgshop.com/product.php?id_product=170) with APM ????
  • MR60
    I wil lbe waiting for the M9, lol.
  • Actually, AFAIK VirtualRobotix uses the 5983. Why 3DR doesn't? I have no idea... My guess would be that they think the improvement wouldn't be great enough to justify the effort and costs of a design and production change for the existing GPS/Compass module and the next version might use a totally different chip....
    I don't really remember much detail about the data - that was 9+ months ago and what I do remember is that I was googling my fingers bloody then to find the differences and data.
  • Thx Stefan, resolution (I guess you are refering to noise floor with 2 milli Gauss) was not comparable with my Honeywell datasheets. Not mentioned for the 5883L. Or is this the digital resolution, they are mentioning just the typical value of the 5883L , while the 5983 is only from 0.75 min or 4,75 max ?  Output datarate is the same at.single measurement.
    But I did not recognize (or find out), that  this is of any importance for our birds , but you obviously noticed a difference, which I did not.  But I admit, I did never test flying along electrical lines.
    What Im still asking myself, why nobody is using or switching over to the 5983 for ready assemblys , same Pinout about the same price (according to the prices of the cheap BOBs Í bought)
    Not even 3DR is recognizing this (Although this 5983 is on the market since a long time, the LEA V1.2 still is coming with the 5883)
    Superb!
