3689363069?profile=originalPowered by a 48 Mhz Atmel AT91SAM7X512 Free tools, all open source code and hardware .NET Micro Framework Event-based programming, multi-threading, line-by-line debugging, and breakpoints.
http://www.netduino.com/
Amazing price I think for only $34.95...mine is coming this Friday...new toys. This will bring a lot of high level programmers into the embedded world, I believe. What would you do with it?
  • The board support package and libraries are all open source, I believe the first and only .net micro framework port to be so, you can buy a raw chip from your favorite vendor and duplicate this thing unlike FEZ which is a black box. It is a more powerful chip than a 1280, but .net does have a lot of overhead, it is hard for me to say at the moment what the comparitive throughput will be. At the moment, my thoughts are that it wouldn't be the best to use as the main processor on autopilot board. I'm going to evaluate it to understand what it is good at to determine what type of applications it is most suited for. The cortex M3 using leaf maples xduino is most certainly a higher performer, faster clock speeds, less overhead. Netduino will be revealing a growth path shortly for other hardware that exposes almost all of the io pins.
    .NET micro framework greatest attribute is using Microsofts Visual Studio IDE, a no compromise obviously fully featured environment. I have not developed with one of these yet, but I'm sure many of you have at least dabbled in creating some simple programs in visual basic at one point or another. The IDE lets you insert breakpoints, inspect variable values etc..troubleshooting code is a breeze without using serial output streams.
    High level programmers I work with talk to me at times about projects they want to make for applications around their house, I usually mention arduino to them. But they are aware of other .net microframework boards, but they have usually been much more expensive. At 34.95, this type of programmer, can develop code for netduino in exactly the same ide as they use during the day at work, it is comforting and familiar, I think the price and platform concept has lowered the barrier for another class of potential microcontroller users.
    And why arm7 when you can get a Cortex M3 cf. Leaf Maple/xduino?
    I don't get the form factor. Where are all those CPU pins going? It seems to have the same IO as a 328 but the size of a 1280.
  • Best of luck, I also like the .net framework. It isn't very well supported by microsoft as yet but it is neat and 4.01 looks great. I think you will only have 120k of program space to play with and i am not sure how well the multi-tasking will handle things in flight. Very interested to hear how you get on
