Bravo, Canada! Read more here:
Think safety first
More and more people are using unmanned aircraft for work or pleasure. Transport Canada regulates their use to keep the public and our airspace safe.
Aircraft without a pilot on board go by many names—unmanned air vehicle (UAV), remotely piloted aircraft system, model aircraft, remote control aircraft, and drone.
Call it what you want, but always think safety first.
Safety guidelines
You are responsible to fly your aircraft safely and legally. In Canada, you must:
Follow the rules set out in the Canadian Aviation Regulations.
Respect the Criminal Code as well as all municipal, provincial, and territorial laws related to trespassing and privacy
Transport Canada expects you to follow these basic Do’s and Don’ts.
Do
Only fly your aircraft during daylight and in good weather (not in clouds or fog).
Always keep your aircraft in sight, where you can see it with your own eyes – not only through an on-board camera, monitor or smartphone.
Make sure your aircraft is safe for flight before take-off. Ask yourself, for example, are the batteries fully charged? Is it too cold to fly?
Know if you need permission to fly and when to apply for a Special Flight Operations Certificate
Respect the privacy of others – avoid flying over private property or taking photos or videos without permission.
Don’t fly:
Closer than 9 km from any airport, heliport, or aerodrome.
Higher than 90 metres from above the ground.
Closer than 150 metres from people, animals, buildings, structures, or vehicles.
In populated areas or near large groups of people, including sporting events, concerts, festivals, and firework shows.
Near moving vehicles, avoid highways, bridges, busy streets or anywhere you could endanger or distract drivers.
Within restricted airspace, including near or over military bases, prisons, and forest fires.
Anywhere you may interfere with first responders
Use this infographic to help you understand the Dos and Don’ts of flying safely:
Permission and safety requirements
To fly your unmanned aircraft legally, you may need to follow strict safety conditions outlined in an exemption or apply for permission from Transport Canada. It depends on the type of aircraft, its weight, as well as how and where you plan to use it.
If your aircraft:
Weighs 35 kg or more, you need to apply for a Special Flight Operations Certificate before you can use it.
Weighs less than 35 kg and is used for recreational purposes, you don’t need permission to fly.
Unmanned aircraft that weigh less than 25 kg may qualify for an exemption to the rules, which will allow you to fly without permission.
If your aircraft:
Weighs 2 kg or less and you can meet the safety conditions in the Transport Canada exemption for UAVs that weigh less than 2 kg or less, you don’t need to request permission to fly.
Weighs between 2.1 kg and 25 kg and you can meet the safety conditions in the Transport Canada exemption for UAVs that weigh between 2.1 kg and 25 kg, you don’t need to request permission to fly. However, you must email Transport Canada or by completing the submission form with:
- Your name, address, and phone number
- UAV model and serial number
- A description of the operation
- The geographical boundaries of the operation
Provide your information to Transport Canada by filling out the submission formIf you cannot or choose not to meet the safety conditions in the UAV exemptions, you must apply for a Special Flight Operations Certificate.
Use this infographic to help you understand the rules and find out if you need permission to fly.
Frequently Asked Questions
Question 1:
Do the exemptions for small UAVs apply to me?
Answer:
It depends on your type of aircraft, its weight, as well as how and where you plan to use it. Our infographic will help you understand if the exemptions apply to you or if you need permission to fly.
If you qualify for an exemption, you must meet the safety conditions at all times. For more information, please read the General safety practices for model aircraft and unmanned air vehicle systems.
Question 2:
What training is required to fly a UAV under the exemptions?
Answer:
Each exemption contains different training requirements. For example, to fly a UAV that weighs between 2.1 kg and 25 kg UAV without permission, the operator must be trained to understand:
airspace classification and structure
weather and notice to airmen (NOTAM) reporting services
aeronautical charts and the Canada Flight Supplement
relevant sections of the Canadian Aviation Regulations.
Question 3:
What is the purpose of a Special Flight Operations Certificate?
Answer:
The Canadian Aviation Regulations require Special Flight Operations Certificates so that Transport Canada can verify that operators can use their UAV reliably and safely.
The Special Flight Operations Certificate contains conditions specific to the proposed use, such as maximum altitudes, minimum distances from people and property, operating areas, and coordination requirements with air traffic services.
Question 4:
How do I apply for a Special Flight Operations Certificate?
Answer:
You must email a detailed application to the nearest Transport Canada regional office. Your application must include your contact information and describe how, when and where you plan to use your UAV, as well as how you plan to deal with the safety risks.
You can find detailed information on what you need to include in your application athttps://www.tc.gc.ca/eng/civilaviation/opssvs/managementservices-referencecentre-documents-600-623-001-972.htm.
If you have any questions about applying for a Special Flight Operations Certificate, please contact your regional Transport Canada office or services@tc.gc.ca.
Question 5:
How long does it take to get a Special Flight Operations Certificate?
Answer:
Transport Canada processes applications on a first-come-first-served basis, and aims to process them within 20 working days. This means:
It may take longer if we must contact you for more information or have received a large number of applications.
You should apply at least 20 working days before you intend to use your UAV.
Question 6:
How long is a Special Flight Operations Certificate valid?
Answer:
A Special Flight Operations Certificate is valid for a limited period of time.
If you have a proven track record of operating your UAV safely, Transport Canada may:
Approve longer-term validity periods
Approve larger geographic areas
Grant new applications more quickly
Question 7:
How does Transport Canada enforce the regulations?
Answer:
Transport Canada regulates the use of all aircraft, manned and unmanned, to keep the public and our airspace safe.
If the department receives a report of an incident, one of our inspectors will verify that the operator followed the rules and used the aircraft safely. Local police may also verify if other laws were broken, including the Criminal Code and privacy laws.
For example:
If an operator is flying for recreational purposes, it’s illegal to fly an aircraft in a way that puts aviation safety at risk. The courts would decide on the penalty.
If an operator doesn’t meet a condition in one of the exemptions, they will no longer qualify to fly without permission and must apply for a Special Flight Operations Certificate.
If an operator is flying an aircraft without a Special Flight Operations Certificate, and should have one, Transport Canada can issue fines up to $5,000 for an individual and up to $25,000 for a corporation.
If an operator does not follow the requirements of their Special Flight Operations Certificate, Transport Canada can issue fines of up to $3,000 for an individual and up to $15,000 for a corporation.
Question 8:
Does Transport Canada plan to review the current regulations for UAVs?
Answer:
Yes. Transport Canada introduced new exemptions for small UAVS in November 2014. The department continues to work with stakeholders and international partners to review and update safety regulations that will address developments in this growing sector and advancements in technology. Our goal is always to maintain the safety of those on the ground and in the sky.
Question 9:
What laws apply to unmanned aircraft?
Answer:
In aviation, you must always think safety first. In addition to respecting the Canadian Aviation Regulations, you must follow the rules in all acts and regulations—including the Criminal Code as well as all municipal, provincial, and territorial laws regarding issues such as trespassing and privacy.
If you think someone has committed a criminal offense, please contact your local police department.
If you are concerned about the safe operation of an aircraft, you can report it to Transport Canada at services@tc.gc.ca.
Question 10:
Why are there so many different terms for unmanned aircraft?
Answer:
You may know them as “drones”, but the aviation community uses many different terms. The words to describe unmanned aircraft are changing almost as quickly as the technology itself.
In Canada, our laws use two terms:
Model aircraft describes those usually used by hobbyists for recreational purposes.
Unmanned air vehicle, or UAV, generally refers to more complex operations used for commercial purposes.
Other countries use the term “remotely piloted aircraft system”, or RPAS. The International Civil Aviation Organization uses this term as a catch-all for all unmanned aircraft.
Call your aircraft what you like—but Transport Canada expects you to operate it safely and legally!
Question 11:
How many Special Flight Operations Certificates has Transport Canada issued?
Answer:
Transport Canada issues more Special Flight Operations Certificates each year, as UAVs grow in popularity. Between 2010 and 2013, we issued 1,527 approvals for UAV operations.
Rob_Lefebvre
H107c (v2) ~56g
But it's seems gigantic in difference from H7 or СХ-10 with weight bout 15g
"Always keep your aircraft in sight, where you can see it with your own eyes – not only through an on-board camera, monitor or smartphone."
Interesting truth matrix is derived from this line.
You can interpret this like so:
- If there is a direct line of sight, you must be able to look at it with your bare eyes, so no goggles.
- If there is no direct line of sight, you can use any visual method you like.
The important words are "where you can see it" ;)
The troublesome thing is that I'm not sure the government is capable of lessening regulations. Maybe if there is an overwhelming outcry, but I don't think I've ever seen it happen. Too bad we don't have the power to offer a deal. "You regulate the Commercial UAV operator's industry less, and in return we'll let you regulate the recreational operators more. Otherwise you won't be able to regulate either, because no one will listen..." Alas, I think the only answer will be for them to begin regulating the companies who make these available to the mass markets, companies like 3D Robotics, and DJI, and Hubsan, etc... DIY builders will never be able to be regulated, but they might end up saying no one can use a DIY craft for Commercial operations, it must have a Serial number, for tracking purposes... I'm not saying it's where I want it to go, but it's where I expect it to go...
Yes, exactly. I don't want to say it but... the problem is they are ignoring the unregulated use of recreational systems. I think they know that there would be a huge backlash if they tried to restrict recreational use. They would have a problem trying to explain why all of the sudden these things are dangerous, despite the fact that they have been flying safely for almost 100 years. So instead, they go after commercial use which is "new", even if using the exact same system the hobbyists are using.
I just don't think it's reasonable to restrict commercial operations so heavily, while allowing virtually unrestricted use recreationally. Again, if at least the commercial regulations were reasonable, it would be fine. And they were so close to being reasonable. But the 9km thing for <2kg machines is just not reasonable.
A commercial operator cannot fly a Hubsan H107D which weighs 100g, 8.9km from town with $100,000+ insurance policy. But I can fly it for fun in my livingroom.
I think all new amateur drone development for canada must lay in lower than 2 kg class =)
But need special requirement for safety flying - like construction materials and specially small size design
Yeah, I see what you mean. Listening to the US Panel yesterday, it sounds like they have no idea what to do with these small UAVs. Some of the discussion is about strobe lights, and radio beacons so airliners can see these things, but at the moment that's not feasible for < 2kg craft. That's at least a few years away before technology might answer that need. The powers that be want to be able to prosecute people that are dangerous with these, but the focus on Commercial operations is silly. I don't want to suggest it, but it's the non-commercial operators that are likely the most dangerous. Someone without awareness, training, or concern for safety of others. Anybody who wants to make a business of this would know that someone getting hurt is the worst thing that can happen. I haven't submitted my SFOC yet, but we'll see how it goes.
Thomas, don't forget though, those 1500 SFOC's does not mean 1500 legal operators. It means 1500 flights. If you consider what that really means, that there have only been 1500 legal flights in Canada over several years, that's not great.
Now, yes, some of those are blanket SFOCs, so they may mean many flights.
But the fact is, if the system is too onerous, people will just ignore it. That is what is happening now, and I really don't think these new rules will change that at all.
I really thought the <2kg class would allow commercial flights with similar requirements to recreational flights. If the 9km thing was only for machines >2kg, I would be fine with that. It would encourage commercial operations to develop small, lightweight, safe machines for usage around people, and that's great. But the way it is now, there's no incentive to do that at all. If I'm going to go through the hassle of an SFOC, I might as well just use my big gas heli because it's easier.
I would say restrictive in a different way. In the US, there are only 6 test sites across the country, and exemptions sought for those areas are given priority. The average startup or real estate agent would not have the resources or time to go through an exemption process. The US has given 11 exemptions to date. Canada on the other hand has given over 1500 SFOCs, not counting ones given this year. Canadian regulations are a boon for agricultural uses of UAVs. I think it's prudent to keep tabs on anyone flying UAVs around people. However, I agree that the SFOC process isn't easy and most real estate agents probably won't attempt it... but at least they could.
These new regulations really are not that forward thinking. The non-SFOC requirements state that you cannot fly within 9km of "built-up areas" where built-up areas is defined as "anything more dense than a farm homestead". This means that the vast majority of use cases in Canada will still require an SFOC.
So, a person can unwrap a Phantom on Christmas morning, and with no previous experience, go fly it in their back yard. However, to take the exact same machine, and use it to take photos of the same house for real-estate, and you must apply for an SFOC. The SFOC process takes at least 20 days to complete, and must be done for every flight plan. IMO, this is actually more strict than the US system, where at least a company can apply for approval to fly on a long-term basis, within a certain set of restrictions.
