Great news! Jordi has now released the awesome new (and tiny!) 10Hz Mediatek GPS module attached to an adapter that makes it 100% ArduPilot (and ArduIMU and ArduPilot Mega) compatible. All in one--no soldering required--and you won't believe how small it is! (And just $38.95!) It's preloaded with custom DIY Drones firmware so it outputs an efficient binary protocol optimized for UAV use. Sample code is provide here and will be added to ArduPilot, ArduIMU and ArduPilot Mega over the next month.
We like this one a lot. It's nearly as good as the uBlox module, but cheaper and smaller. We'll be supporting it as a recommended GPS module going forward.
Here's the product description:
USB/UART Interface
Build-in patch antenna for optimal sensitivity
DGPS(WAAS, EGNOS, MSAS) support (optional by firmware)
Maximum update rate : up to 10Hz (optional by firmware)
RoHS compliant
-Based on MediaTek Single Chip Architecture.
-Dimension:16mm x 16mm x 6mm
-L1 Frequency, C/A code, 66 channels
-High Sensitivity:Up to -165dBm tracking, superior urban performances
-Position Accuracy:< 3m CEP (50%) without SA (horizontal)
-Cold Start is under 35 seconds (Typical)
-Warm Start is under 34 seconds (Typical)
-Hot Start is under 1 second (Typical)
-Low Power Consumption:48mA @ acquisition, 37mA @ tracking
-Low shut-down current consumption:15uA, typical
-DGPS(WAAS, EGNOS, MSAS) support (optional by firmware)
-USB/UART Interface
-Support AGPS function ( Offline mode : EPO valid up to 14 days )
State-of-the-art 66 channels MediaTek MT3329 GPS Engine
High sensitivity: Up to -165dBm tracking, superior urban performanceUSB/UART Interface
RoHS compliant
Note that the new MediaTek has custom and exclusive "DIYDrones" firmware that allows the unit to output an efficient and very compressed binary protocol. You can still change between NMEA and Binary protocol with standard MTK messages, and switch the refresh rate between 1hz to 10hz, or set any standard serial baud rate (by default is set to 38400 bps and custom binary protocol).
Features:-Based on MediaTek Single Chip Architecture.
-USB/UART Interface
To add to that, we have comments from Chris Anderson which berate one product and endorse another (which they happen to sell)... despite the fact that Sparkfun did objective testing and concluded otherwise. When asked about his methodology, he responds with sarcasm while admitting to being subjective rather than objective in his testing. That's the type of "technology" and "technological advice" you get, and yet you feel they should be immune from criticism (while running a for-profit business that uses bits and pieces of the free software others develop to power their own products, without so much as crediting those open software projects).
That sucks.
chris.
Chris - What is the factual basis for your claim? The Sparkfun tests (as opposed to subjective opinion or just plain conjecture) clearly show that the older MediaTek MT3318 with a passive antenna outperforms the U-Blox even with an active antenna. What is the basis for your claim?
Also, what is your definition of "nearly as good?" I have difficulty following flowery generalizations using vague and ambiguous terms, especially when claims are being made that go against the grain of formal tests.
Jordi, where can we find the documentation on the "custom and exclusive" binary protocol? Since it was mask programmed exclusively for DIYDrones, and you're selling it (as well as the MT3329 without the board), then I imagine you'd already have the documentation for the binary protocol. Please post a link to it... the link in the store is just to the "standard" version.
How did you get the manufacturer to crank out "customized for DIYDrones" versions of their firmware, without committing to huge (100,000+) quantities? Also, in order for the manufacturer to customize it, you must have given them some specs as to what you wanted the binary protocol to look like. In other words, if it was customized to your specifications, then by definition you already have those specifications. Could you post them (the binary protocol), please?
Or is there more to this than meets the eye?
1
2
3
4
of 4 Next
