If you update to the latest Mission Planner (1.05) you'll see a cool new feature Michael Oborne has just added: integrated OSD video! Just select your video input device from your aircraft's camera feed from the Configuration screen (Planner tab) and it will replace the background of the artificial horizon on the GCS, turning it into a heads-up display instead, as shown in the left window above.
Pretty cool, huh? It's a virtual OSD!
Michael,
Here is the Planner message:
Michael,
Thanks for the super Mission Planner suite of tools. They work great!
During flight I would like to use HK GCS (because of voltage indication, audio output, logging, etc.) but I would like to have the Planner 'Configuration' window open too. Inflight adjustment of PIDs makes the tuning process almost easy.
If I connect Planner first - when I connect HK GCS I get no connection and a message: "Access to the port 'COM5' is denied."
If I connect HK GCS first - when I connect Planner I get:
Is there any way to have both connected at the same time?
Thanks.
Great stuff!
Any way to avoid the xbees ? Like multiplex the signal into video link maybe ?
It's cool!!
