I'm using RFM22B radio modules and ATMEGA328P chips on Rx and Tx.
Rx modules including 8 channel servo ports and RS232 for telemetry uplink
Tx modules including PPM-Input for analog servo control and RS232 for Computer based controls and Telemetry downlink.
System range will be around 4-5km.
Firmware Upgradeable over RS232.
Ground tests was unbelievable, it's working around 500 meters into the city (after 20+ concrete building)
I will share the flight test results, sources and schematics soon.
If you have any idea about design and inputs, please share with me before 4th generation's production..
Thanks for reading
Melih
Any news on this front? Really interested...
@Ivan
No, first 3 version was only for my personal tests. I2m designing v4 for publishing. It's not including an LCD, you can use your computer for telemetrey ;)
Melih,
Will v3 boards also be available in your shop? I don't need no LCD screen for telemetry when I have a big screen on my laptop.
@Kamu
Our Tx module smaller than all modules(futaba or jr). you can put it into the old modules.
That's a great question Kamu. I wonder if these will be a DIY module that is to fit inside the transmiter like the Frysky unit or if it could fit inside a module that we could swap out for our regular 2.4Ghz gear and recievers. I'd be willing to trash one of my Turnigy modules for a re-fit to be able to swap it out.
Rx and TX boards same on v3 boards. Because both side using transceiver modules and all boards Tx+Rx ;)
But i'm changing the design for v4, and Rx module including RSSI and SerialPPM outputs. Tx board have a buzzer and less pinouts.
I'm designing a telemetry LCD screen and some sensors now and waiting for sample parts for tests, then i will order the PCBs.
- Wide Band 450mW transmitter module
- UHF Multi-Channel transparent data link
- QPX1 2Watt VHF radio link transceiver
- 500mW VHF transceiver module
... any many other toys! Just scroll down this page link.
Andrew.
this would allow you to do servo PWM in hardware leaving the microcontroller with far more time to do other things.
i use a single ATMEGA2561 to run a 2.4GHz module, measure current draw and battery voltage, act as an IMU and still have enough processing time left over for autopilot route planning.
this would not be possible if the AVR was having to do PWM in software.
on the down side, it would increase the cost a little....
i appreciate simple is good and this may be out of the scope of your project,
but versatile is good too.
a more powerful microcontroller that could do servo PWM in hardware and have some spare analogue inputs that could would allow aircraft battery monitoring would allow some powerful functionality.
dunk.
1
2
3
of 3 Next
