NEW Gimbal
Gimbal Capabilities
- Size (DxH): 100mm x 129mm or 3.9in x 5.0in
- Weight: 695g or 1.5lb
- Power: 12W
- Position Accuracy: 0.022° or 380µrad
- Elevation: ±115°
- Azimuth: 360° Continuous
- Slew Rate: 105°/s or 1.83rad/s
Video Output
- Analogue Output: Composite
- Digital Output: .h264 up to 10Mbps
- Snapshots: HD (Stored on Board)
- Streaming: EO 720 x 576 and IR 640 x 480
CM100
The Latest Gyro-Stabilized Multi-Sensor
- Dual Sensor - EO and IR in the Same Unit
- No ITAR or Export Restrictions
- Low Size, Weight, Power and Cost
- IP63 Rating
https://www.youtube.com/watch?v=cLOWcIBBIk8
https://www.youtube.com/watch?v=28nVA8CmKPA
https://www.youtube.com/watch?v=0dGx8cUsM4c
I commented on DIY drones after seeing the product listed by another. Just in order to let potential customers know that this product is available in the US. The price is not at hobby levels, these are professional grade equipment with high reliability and sub 0.2 degree stability, geo lock, moving target lock, laser target marker etc. We don't have a price online because it very much depends on what specific internal and external equipment you need, numbers you order etc.
It's just their way of saying "This is going to cost you lots". Which is kind of ok, after all it is most likely a good product. I'm just wondering why put it on diydrones. It's a bit like making a blog post about a ScanEagle. Awesome piece of kit, sure, but who can afford it? I'd much prefer a diy design option to this, with comparable performance.
Really annoys me when they don't have a price online and u think ill join to find out and you cant find out. Forget it ill look else where
Anyone want a left kidney? Well looked after...no alcohol damage...
Absolutely, but it very much depends on the specs you order. They are probably beyond the price for hobbyist, but for professional applications you will find the price very competitive.
Please contact me via my email deanattridge@sentinel-air.com for more details.
I have recently become the US Agent for these sensors and my demonstrator CM100 arrives in January. There are multiple options for the internal cameras for the CM100, both ITAR controlled and ITAR free. These are professional grade equipment, but very cost effective when compared to the competition. The software and full Ethernet control make deployment options very flexible.
Is ITAR an issue? UAVVision seems to be Australian judging by their address. I thought ITAR relates to the export of US product from the US.
Peter
I think you might be correct. The low rate ones are export controlled by country and the high rate ones probably require an end user certificate or some such. At any rate: If I have to ask about the price, I probably can't afford it.
The only way to avoid ITAR with IR is frame rate, afaik. There is no "getting around" ITAR - "Getting around ITAR" is generally bankruptcy or jail time territory :-)
I imagine this will be out of reach for most people?
1
2
of 2 Next
