Overlaying GPS Coordinates for Camera Crosshairs
3689560630?profile=original
Hey Guys!
I am working on a project to allow us to implement GPS coordinates for the location of the crosshairs of a PTZ camera, other wise known as Geo-pointing.  This will essentially give us the LAT/LONG of what we are looking at.
I have found several methods to do this, but I'm looking for the simplest way but accurate as possible.  I am fairly new to modifying APM and to MAVLink so instruction and suggestions are very welcome!  Here is what I have in mind:
In order to get this:
LAT/LON: Self explanatory
BRG: Bearing
SRG: Slant Range (Range from Aircraft to location)
GRG: Ground Range (Range from coordinate to coordinate)
I have a formula to triangulate the position of where the crosshairs are pointing relative to the aircraft by using trigonometry.  Here is the example:
3689560667?profile=original
3689560688?profile=original
The system will incorporate 1x APM 2.5 w/ GPS, 3DR Telemetry radios, 1x IMU w/ compass for camera gimbal, 2x MinimOSD boards, 2 cameras, 1x video TX with two-way camera switcher.
Method:
Application extracts altitude from APM and camera angle from Camera IMU and finds the tangent and cosine of the angle and finds the missing sides.  This will give us the ground distance and slant range respectively.
TAN(CAng)*Alt = GndDist     COS(CAng)*Alt = Slant
At this point the slant and ground range can be transmitted to the video feed.
Next, we use the aircraft's GPS coordinates from the APM and the ground distance to find what coordinate we are looking at on the ground:
aL-aircraft Latitude
aO-aircraft Longitude
cL-crosshair Latitude
cO-crosshair Longitude
A-aircraft Altitude
D-ground Distance
B-Bearing from Gimbal Compass
cL =ASIN(SIN(aL*PI()/180)*COS((D=TAN(A*PI()/180)/6378.137) + COS(aL*PI()/180)*SIN((D=TAN(A*PI()/180)/6378.137)*COS(B*PI()/180))*180/PI()
cO =((aO*PI()/180) + ATAN2(COS((D=TAN(A*PI()/180)/6378.137)-SIN(aL*PI()/180)*SIN(cL*PI()/180), SIN(B*PI()/180)*SIN((D=TAN(A*PI()/180)/6378.137)*COS(aL*PI()/180)))*180/PI()
These formulas are in excel format since it is what I used to test these.
This should give us the coordinate under the crosshair.
Next, I would like for this information to be sent to the second OSD for the gimbal camera.
Now my question is, how do I implement this?
I would assume that I can attach the IMU and compass via analog sensor input, however, I have no idea how to write code for it.
I also do not know how to write the code for the calculations to the APM in order for the APM to do all the formulas.  Can the APM handle it or do I need a separate processor?
How do I create a MAVLink message for the new coordinates and inject into the data stream?
How do I write the code to the MinimOSD to retrieve the new coordinates and display it?
These might sound like noob questions, but I come from a radio frequency engineer background and just now getting into programming.  I would love to learn how to do this stuff but there is very little out there on what I'm wanting to do exactly.  Sure, I can make an LED blink, and I know that's the basic skills, but I need to know how exactly to interface this with the APM and sensors.
Once again, all of your help is greatly appreciated and I very much welcome discussion and suggestions on a better way to do this!
-Hunter
  • But then again, our aircraft are FL200+, so maybe this isn't an issue, and the simple calculations aren't that crazy to process on-board...
  • In the MQ-1 and MQ-9, we use DTED (Digital Terrain Elevation Data) that resides on the computers that run the GCS for the calculation of TGT coordinates, slant range, ground range TGT elevation and "other stuff".  The elevation of the TGT makes a huge difference in the computed TGT coordinates.
    Another advantage of processing it on the ground is that I can use non-destructive GCS generated graphics to see where my crosshairs are pointed without destroying any of the MTS video.  The added benefit of offloading the task of computing crosshair location is the ability of having huge areas mapped out for the DTED data.  We have the ability to use destructive overlay graphics that most people are used to seeing in the RPA videos on YouTube, but I prefer not but still be able to embed the info in metadata.
    Hope I'm not rambling!
  • It all comes down in solving the camera pointing algorithm in the reverse order, as Lucas suggested. Within this algorithm there are three variables:
    1. Own (GPS) position, altitude
    2. Target position, altitude
    3. Pant tilt X and Y values. X for pan Y for tilt.
    The current algorithm gets the values from 1 and 2 above and calculates the pan/tilt angles that subsequently drive the servos.
    In your case, solve the algorithm by giving the 1 and 3 values and get the target coordinates.
  • Anyone have a suggestion on how to write this code to Arduino and APM?
  • I checked out magnetsystems.net.  They're stuff is pretty impressive.  But it still runs the question of cost.  It seems this is tailored to military and law enforcement so the cost would seem to be out of the reach of the hobbyist.  I want to make a low cost system that will be readily available to everyone, even the hobbyist.  The formulas and implementation doesn't seem that hard, it's just getting it done.  I appreciate everyone's input on this.  You all have been fantastic over the years.
    Home
  • These guys are doing it already for quite some years now as far as I know: http://magnetsystems.net/
    They provide the coordinates not only of the crosshair location but from every pixel of the video window. An impressing technology called video draping that georeferences in real time the video from the UAV to its actual location on the ground.
    Click on the video draping link and watch the videos. I have seen this technology in action and it allows you to hover the mouse over the draped video window to get real time geographic coordinates out of it……
    Home
  • Basically the existing code does it the other way around:
    - You tell the target coordinates (including altitude) and it points the camera there.
    What you plan to do is the other way around:
    - You point the camera manually at some point, and it tells you the target coordinates (including altitude)
    My guess is that you need to invert the transformation matrix, and you are done. But this is just a guess, I have not though about it fully.
  • Hunter,
    It's actually much easier than that. You don't need a seperate IMU gimbal controler code all ready does almost all of the steps needed. I am very familair with the Mount code and could have it working prety quick asssuming we are flying over flat terain. If you target is at a different altitude than you takeoff point then it gets more complicated. The initial soloution would need to be feed to the GCS and google earth would need to come up with an elevation based on the initial flat terain assumtion and this would then change the lat/lon soloution of the target. It would have to go through a few itterations of this process for the true soloution to converge where lat/lon and altitude are all on the same point. It's been something I have been meaning to work on. I have a plane with a pan/tilt gimbal and can maybe test out a flat terain methode this weakend. The elevation based soloution will ned work done in MP and I don't know how to do that.
    You should look at the mount.cpp code particularly the calc_gps_target_angle code at line 573.
  • Awesome stuff. I'm pretty familiar with GIS, now, how to add that pesky ASCII or Arcdata to arduino...
  • Russkel,
    You are correct. I believe there are libraries for elevation calculation based on coordinates. Similar to the way Google Earth can tell elevation under mouse pointer. If that's the case, I'm definitely going to have to have something more robust than the APM for computing. Any ideas?
    Great idea for kickstarter! I might look into to that being the only geo-pointing module I've found is made by FLIR, and we can imagine how expensive that is!
