Pilot's logbook
3689562216?profile=originalIn an effort to further professionalize the operation of drones, I was looking around for templates where I can log flight hours and model maintenance. I want to be able to turn over some documents that show flight hours, experience and that I'm serious about how maintenance and flights are executed. To interpret this correctly, I add that I restrict operations to the following constraints, based on what current legislations seem to agree on internationally. These are 6 simple rules that I always comply with:
  • less than 3.5 kg model weight
  • less than 400ft altitude
  • less than 500m distance
  • non urban areas
  • permission of land owner
  • 2 miles away from airports and helipads, or prior contact and flight scheduling
It doesn't make a lot of sense to copy verbatim the logbooks used in general aviation. First, the type of piloting/operation is very different. Second, the importance of the motor, propeller versus the rest of the equipment is negligible, so separate logbooks for motors and props don't make sense.
So I've started on a little suite of apps for Mac OSX where I intend to keep my own logs. They will be kept for a month and then printed, signed off and archived. The one above is the pilot logbook, an example of general aviation available here:
https://dl.dropboxusercontent.com/u/11452962/Pilot_Logbook.pdf
As you can see, the "condition of flight" and "piloting time" you find on those logbooks do not reflect how drones are usually operated. You can be either pilot in control (having direct manual control), but in other cases allow the drone to be operated automatically through an autopilot, in which case you become an operator in control. There are also other options like instructor or receiving instruction from others, all which counts towards flight time. The condition of flight is also different. It doesn't make sense for civil applications to fly in night time or in IFR conditions, because you must always have VLOS.
I think the most important contribution is the 'stress level' column. This reflects the maximum stress level of the pilot/operator during the flight. The idea is that the pilot reflects on the flight and determines what made him feel uncomfortable. It may be that training is needed to deal with flying close to equipment installations. In other cases it may be high wind situations and not feeling entirely in control of the craft. In the end, the objective is to find out where additional training is required, or find out where technology can be improved or substituted to remove this anxiety. So I think this column really helps to make future flights safer and safer.
I intend to make similar apps for maintenance activities on aircraft and a separate 'crash analysis book'. The objective is to demonstrate that aircraft are subject to regular maintenance and that crashes are taken seriously and need to be analysed in great detail to take measures that prevent them in the future. I think those 3 books should be enough for crafts and operations this small (subject to above constraints). In comparison, full-scale aviation has at least 5 logbooks to keep and I do not see any value in complying with those bureaucratic demands.
The idea is to demonstrate commitment to safety when operating the technology at somewhat larger scales. The logbooks aren't necessarily legal or approved, but they're certainly better than nothing or statements like "well, we never had an issue in about 200 flights we executed". Also, when people start flying for you, you want to have insight into what makes people nervous, what the frequency of maintenance is, what they find there, which components need replacement often, do we need to switch suppliers and so on. So also from a financial and general operation perspective, it makes sense to start tracking what goes on in the outfit.
Comments are welcome.
  • A Logbook APP would be nice, but I'm still "partially" old school so I created a Logbook specific for Drone Pilots or maybe just specific to my needs. You can find it on LULU.com
    LOGBOOK FOR DRONE PILOTS. Keep track of your UAV/DRONE flight time. With the new FAA regulations about drone commercial flying you will probably have to demonstrate proficiency and  experience. This logbook will let you record date, drone make and model, location, spotter's name, weather conditions, batteries used, Camera used, Day/Night/FPV time, training/hobby/commercial time, number of takeoff and landings and total flight time.
    http://www.lulu.com/shop/keep-them-flying/drone-pilot-logbook/paper...
  • Hi,
    3701820990?profile=originalWe have developed a suite of mobile and cloud / desktop applications on Android, iOS app and RPAS / sUAS / UAV / Drone Job Management website that integrates with your mobile devices called RPAS Logger (Remotely Piloted Aircraft System = RPAS ) to be used as a drone logbook.
    The apps include a bar code scanning feature for battery / maintenance management and our latest (most requested feature) allows you to use your GPS location on your mobile device to show you the nearest airport / helipad etc to your current location which will help in completing your Risk Assessment for each job or flight. www.rpaslogger.com
    RPAS Logger EnterpriseThis is the flagship version of RPAS Logger. Unlike the Lite and Pro version, RPAS Logger Enterprise is a cloud-based solution. All Data is kept in the web application and your mobile devices will now become access points that you will be able to use on and off line to collect and log data.
    It is oriented towards a commercial operation. It will allow you to create jobs for customers, assign equipment and personnel to different jobs, manage area approvals and risk assessments, manage maintenance requirements and inventory.
    Modules will include:
    Basic Module – everything required to create jobs, manage airframes, batteries and role equipment usage, manage pilots (including type endorsements and certifications) and produce comprehensive reports.
    • Maintenance Module – Keep maintenance logs for all equipment and manage your inventory - including shelf life and minimum quantity reporting.
    • CRM – Integration into popular CRM modules, or use our vTiger based CRM. Integration for popular financials applications (like XERO)
    • UOC Manuals – online management of your flight, operations and maintenance manuals. Easily update your entire documentation suite with any changes that you make to your fleet, role equipment or operational parameters.
    We will appreciate any feedback or request for new features. Rest assured, we have a long list of upcoming features but use your comments to help prioritise our updates.
  • Great concept. APM is a great tool for flight planning. For a simpler database logbook, I found uastracking.com which is more of a pilots logbook tailored for drone ops. I will be using both.
    Best of luck,
    AV
  • Hello,
    I have created an online Drone logbook. To save major information: Drone, flight, places, maintenance. It's a first beta version. I try to get feedback from other users. It's free and the link is here: http://drone.cloud2.mobi/.
    You are welcome to give it a try and send me your feedbacks / wishes with the contact form. I will do my best to adapt it to your needs!
    best regards,
    Yv.
  • A log book integrated into mission planner would definitely be the way to go.
    There could be so many things automated in the logs, like flight time, battery consumption, air speeds at different altitudes, time of day and as mentioned previously it could log changes to PID loops or any parameter you've changed and link this to the telemetry log so you can go back and replay the flight to see how the changes relative to the weather changed the characteristics of your plane.
  • In addition to building and flying multicopters (cc3d, apm1 & 2, kk2), I also keep bees. There are a lot of things to keep track of each time I inspect the internals of one of my hives. I have used spreadsheets and created forms. There are mobile apps that do it. The problem is this: as I evolve as a beekeeper, I keep seeing new data fields that needs to be added and old data fields that need to be deleted. The data collection process evolves as I do. Static forms become a source of frustration.
    Today, I use Evernote (from my Windows 8 phone...also available on Android & iPhone). It is free. My dated but otherwise free form comments go into a unique note for each hive. Every note is kept in a named folder. Everything gets replicated automatically to my desktop along with shopping lists and to do lists. This is how I plan to track non-trivial or eventful missions...though I can see the value of linking flight logs to a pilot's log.
    But forget about forms with fixed data fields. You will never agree on what those fields should be with the next guy or even yourself in 6 months.
  • Another thing which would add to this in mission planner, is to identify which craft is being connected to, and to log any changes (PIDs or otherwise) so that an accurate log of changes and subsequent observations relating to performance can be kept in one place.
  • Yep, I agree! This should be an automated feature in mission planner.
    Well done Gerard I have been keeping a log in the form of a spreadsheet for some years now.
    It really should be part of mission planner and I would like to see users able to send data back to a central spot so we can say APM has flown X hours fixed wing Y hours rotary.
    I have said this on many, many, many occasions.
    Its good enough for Parrot, this from when they broke the million flights.
    3692896008?profile=original
    They are going to hit 2 million very soon.
