Here it is! Finally, the PixHawk Fire Cape (PXF) is ready for a wider audience and we've launched a crowdfunding campaign so that everyone can get theirs. We've been iterating through different generations over the last year and with the help of many, we are finally proud to announce the PXF starting at $100.
This board was born out Philip's hands and pushed by members of this community so it's just reasonable to try making it as affordable and accesible as possible. Some technical details:
Sensors
- MPU6000: 3-axis gyroscope, 3-axis accelerometer and temperature sensor.
- MPU9250: 3-axis gyroscope, 3-axis accelerometer, 3-axis magnetometer and temperature sensor
- LSM9DS0: 3-axis gyroscope, 3-axis accelerometer, 3-axis magnetometer and temperature sensor.
- MS5611-01BA03: Barometer that includes pressure and temperature sensors.
Connectors
- 3x LED indicators (Green, Amber and Blue)
- 2x serial UART ports (ttyO0 is not active)
- 1x CAN connector and transceiver
- 3x I2C ports
- 1x Buzzer
- 1x Safety switch
- 9x PWM output channels
- 1 PPM/S.Bus in
- 1x Spektrum
- 1x Power brick connector
- 1x Battery backup (1 LiPo cell)
- 1x ADC
- 2x GPIOs exposed (IO)
- 1x analogic pressure sensor (AIR)
Mechanical characteristics
- Size: 88.6 x 54.73 x 20.69 mm
- Layers: 6
- PCB Thickness: 1.62 mm
- Weight: 31 grams
Support the crowdfunding campaign of the PXF here.
Doug,
You're right about the flying matter. It's indeed valid for non-aerial platforms. I actually have in my desk a new robot configuration that does not fly at all and is powered by the PixHawk Fire cape.
For much that we might like the BeagleDrone concept, there's already a BeagleDrone cape (http://beagleboard.org/project/BeagleDrone/). We also came up with "BeagleAPM" or but "BeagleUAV" seemed more commercial.
Reply here also: https://www.reddit.com/r/diydrones/comments/30gqho/beagledrone_beag...
Ok, so is this board only used on UAVs? What about rovers and surface or for that matter undersea applications?
Just my two cents on the name of it, I think BeagleDrone or BeagleUS (US = Unmanned Systems) would be better. That way it umbrellas all platforms.
Could the authors reply here also: https://www.reddit.com/r/Multicopter/comments/30gpc9/beagledrone_be...
Hugues,
The 90 € was an early bird. The cape is the same.
Having an "early bird" price is a common practice in crowdfunding campaigns to get an initial set of funding. We need to push through that line though.
Any recommendations are welcome!
Kind regards,
Hi Victor, whar's the difference between the 90eur and the 120eur perk ? Hesitating between the two...
Named changed to "BeagleUAV" (BeagleDrone was another project).
Thanks everyone for the tips and support.
Regarding previous comments on the goal, it has been set to 25.000 € to get the offered perks/rewards. Big batches lower production costs.
Victor I'm very impressed. Only a few of us voiced our concerns and you have resonded in a very positive manner.
Backed for 2 early birds.
I will advertise your cape.
I vote for BeagleDrone.
BBB is something someone has to find out, thus just Beagle is better. Drone tells what's all about.
Agree with Chris as well.
So, why is Fire in the name? Was there a Thermal Event in the design and testing at some point? ;)
I'm in for an Early Bird.
1
2
3
4
5
of 5 Next
