Polarity Protection for Turnigy 9x Tx
3689410637?profile=original
3689410705?profile=original
3689410778?profile=original
http://www.sparkfun.com/datasheets/Components/General/FQP27P06.pdf
3689410816?profile=original3689410726?profile=original
3689410837?profile=original3689410873?profile=original
I'm currently waiting for my new Tx in the mail and will be doing a video.
 You can use either a "P" or "N" channel Mosfet will work.  This curcuit works better than the Crowbar curcuit because it doesn't need a fuse, and with  less of a voltage drop.  "N" channel Mosfets are more common to find and be to used.   I have decieded to just make a reverse polarity connector instead of Modding the radio for a now.  I removed the charge port connector from the radio to use as passage way for my wiring.
3689410886?profile=original
I used a balance connector to connect to the 11.1v Lipo.
3689410800?profile=original
I removed the Tx charge connector and enlarged a whole for the wiring to pass through.
3689410905?profile=original
3689410922?profile=original
Finished it up with some Velcro to hold the battery.  I have already noticed with a 1600mAh 11.1 LiPo my battery life has increased by 2 to 3 or more hrs.  SWEET!
Even better protection using both a mosfet and a charge pump IC.
3689411025?profile=original
You can find the Charge Pump IC's online.
   Here:    Charge Pump IC
  • Just use a Schottky diode, voltage drops only ~0.3 volt and it protects your circuit. If you can find a FET without internal diode, your circuit works.
    PS: Use a LED or multimeter for testing your circuit. It is better than a motor.
    http://works.PS/
  • Added a video to blog.      It's working great
  • Sorry guys I was wrong.  Ross I had to check my self, I did have it backwards, thanks for the look out.  I have changed the wiring diagraim up top I have also added a video.
  • @ Ross I don't have it swapped
    Get a P ch-Mosfet and try it with a DC brushed motor and a voltmeter.
  • I'm curious now, maybe you have Drain and Source swapped? If you disconnect the Gate altogether, does it still work correctly?
  • I tested my curcuit with a 11.1v LiPo, P ch Mosfet, and an electric brushed motor.  If i connect my battery the correct way the motor spins.  if i connect the battery the wrong way "reverse" the motor does not spin.  To me that is working correct.
    @ darren  I would not use this with high current.
    @ amilcar Look again,  The diode drains almost .75v and you still need a  .33 amp  fuse.  I never tested with the "N" ch- Mosfet,  I was told in the sparksFun forum about this and to stay under 750ma  rated curcuits.
  • Yeap the mosfet body diode will conduct when the batery is reversed.
    It will not work, just use a simple diode instead.
  • is that something that can be made into each lipo conector? ie, would that help in the same reversal on an esc connector? ive done that too :(
  • My stock FlySky has built-in polarity protection.  It merely has a series diode on the positive battery input.
    I don't think your circuit will protect it from anything.  The body diode of your MOSFET will allow current to travel if the battery is connected in reverse.  Your MOSFET is upside-down, but you might as well just use a diode to block reverse voltage.  Please correct me if I'm wrong though, I'm a bit rusty on my circuit components.
  • By the time you get done doing all the mod's you end up with a really nice radio.  All in all it's worth it.  I just don't want anybody else to have to go through the pain of burning up a new radio like i did.
