Almost exactly one year after the first PX4 announcement, we would like to introduce our newest member of the family, Pixhawk! For those familiar with the existing PX4 electronics, it is the all-in-one board combining PX4FMU + PX4IO, combined with a processor and sensor update and a number of new features. The current board revisions will however remain in full service and active development and are fully compatible. Pixhawk is designed for improved ease of use and reliability while offering unprecedented safety features compared to existing solutions.
Pixhawk is designed by the PX4 open hardware project and manufactured by 3D Robotics. It features the latest processor and sensor technology from ST Microelectronics which delivers incredible performance and reliability at low price points.
The flexible PX4 middleware running on the NuttX Real-Time Operating System brings multithreading and the convenience of a Unix / Linux like programming environment to the open source autopilot domain, while the custom PX4 driver layer ensures tight timing. These facilities and additional headroom on RAM and flash will allow Pixhawk the addition of completely new functionalities like programmatic scripting of autopilot operations.
The PX4 project offers its own complete flight control stack, and projects such as APM:Copter and APM:Plane have ported their software to run as flight control applications. This allows existing APM users to seamlessly transition to the new Pixhawk hardware and lowers the barriers to entry for new users to participate in the exciting world of autonomous vehicles.
The flagship Pixhawk module will be accompanied by new peripheral options, including a digital airspeed sensor, support for an external multi-color LED indicator and an external magnetometer. All peripherals are automatically detected and configured.
Features
32 bit ARM Cortex M4 Processor running NuttX RTOS
14 PWM / Servo outputs (8 with failsafe and manual override, 6 auxiliary,
high-power compatible)
Abundant connectivity options for additional peripherals (UART, I2C, CAN)
Integrated backup system for in-flight recovery and manual override with
dedicated processor and stand-alone power supply
Backup system integrates mixing, providing consistent autopilot and manual
override mixing modes
Redundant power supply inputs and automatic failover
External safety switch
Multicolor LED main visual indicator
High-power, multi-tone piezo audio indicator
microSD card for long-time high-rate logging
32bit STM32F427 Cortex M4 core with FPU
168 MHz
256 KB RAM
2 MB Flash
32 bit STM32F103 failsafe co-processor
ST Micro L3GD20H 16 bit gyroscope
ST Micro LSM303D 14 bit accelerometer / magnetometer
MEAS MS5611 barometer
5x UART (serial ports), one high-power capable, 2x with HW flow control
2xCAN
Spektrum DSM / DSM2 / DSM-X® Satellite compatible input
Futaba S.BUS® compatible input and output
PPM sum signal
RSSI (PWM or voltage) input
I2C®
SPI
3.3 and 6.6V ADC inputs
External microUSB port
Power System and Protection
Ideal diode controller with automatic failover
Servo rail high-power (up to 10V) and high-current ready (10A +)
All peripheral outputs over-current protected, all inputs ESD protected
- Monitoring of system and servo rails, over current status monitoring of peripherals
Dimensions
Weight: 38g (1.31oz)
Width: 50mm (1.96")
Thickness: 15.5mm (.613")
Length: 81.5mm (3.21")
Availability
This announcement is a service to our users and developers to allow them to plan their hardware roadmaps in time, and to show what we're currently working on. The board will not be immediately available, but 3D Robotics is taking pre-orders for Pixhawk now, and will begin shipping in late October [Update 11/11: the current expected ship date is late Nov]. The price is $199.99.
Hi Martin,
Either Spektrum (with a satellite receiver) or Futaba with SBus receiver will work very satisfactorily.
The HobbyKing Turnigy 9X and 9XR radios (with a FRSky module) is a very popular choice.
A very interesting and currently hard to get option because they cant build them fast enough and the one I will be getting next is the FR Sky Taranis. http://www.frsky-rc.com/product/pro.php?pro_id=113
These are all good choices and support our PPM-SUM needs.
However, for you, another option might be: For a lot of JR radios you can also get a FRSky module that plugs in the back that will let you use the PPM-Sum compatible FRSky receivers.
http://www.frsky-rc.com/product/pro.php?pro_id=8
Gary M: Thanks for the welcome back. I've spent the better part of the last year face first into land based R/C stadium trucks and the like and I just recently bought another plane. I'm planning on building up a penguin V2 for FPV. I'm going to stay with planes for now but I have bought a small blade mqx that I want to try and fpv with lol.
Who is developing the software and testing it for this unit?
Aym: Yes, it has the power for the that and it's on the software roadmap.
@Lorenz Meier. That's a good start. Are the mixer parameters edited through mavlink?
Need to add multipoint and conditional mixers before it is compatible with more complex airframes.
Is the Pixhawk flight controller capable of PIDs auto tuning?
ok that's great to know :) ,I had figured it was likely
I like the design tho ,I was convinced it was one of those tactile reset bubbles without following every post :)
Charles: Pixhawk also supports an external multi-color LED for exactly that reason. That's what Iris uses.
ok Gary it's strange that there would be a multi color led and also small ones on the same surface to indicate the same things an external led connector solution would seem better for outside an aircraft fuselage or rear/side for a Multirotor ,kinda hard to see leds, its not exactly the smartest thing to stand over a Multirotor especially while arming, how is one to see a top mounted led while in a hover?
What is the better radio to get for the PIXHAWK,Spektrum or a Futata 8 with S Bus I have a JR 8XG at preseny,thanks,Marty
Question asked by Ilya and answered by Jordi and Chris on Pages 6 and 7 of this Blog indicate it is for the RGB LED.
