Hi all!
We are glad to announce the start of crowdfunding campaign for Reach - compact and affordable RTK GPS receiver, capable of centimeter-level precision.
RTK is a widely used technology well-known in surveying and precision agriculture. Currently available systems cost thousand of dollars and are not affordable to hobbyist, makers and small businesses.
Reach has a tiny Linux computer inside, which runs open-source RTKLIB engine and has comprehensive connectivity options. Bluetooth, Wi-Fi, Serial, USB on-the-go - whatever your application is, integration would be seamless. Reach can be connected to the internet and work independently with NTRIP casters. Here is an example of Reach installed in a vehicle compared to a standalone GPS:
We are working on integration with Pixhawk and other APM based autopilots. Reach can be powered from autopilot port and will send accurate coordinates using NMEA protocol.
Great antennas are the key for RTK performance. Tallysman Wireless, an industry leading company in high accuracy antennas provided their latest advanced antennas for the project. These antennas receive Glonass G1, Beidou B1, GPS L1 and Galileo E1 signals as well as signals from corrections services.
The Emlid Reach program is an excellent example of the potential for huge reductions in cost available of precision RTK positioning systems. Tallysman’s Accutenna™ technology is a great match for the Reach product because it too provides high precision at new price levels. Just as one wouldn’t expect a high quality image from an expensive TV receiver with a “rabbit ear” antenna, one should not expect the levels of precision the Reach product is capable of with a low precision antenna. Tallysman’s raison d’etre is production of high quality, high precision antennas at an affordable price for systems exactly such as the Emlid Reach product.
Allen Crawford – Director Marketing & Sales, Antennas and RF Products, Tallysman Wireless
Reach highlights:
- Raw data receiver: U-blox NEO-M8T - 72 channels, output rate is up to 18Hz, supports GPS L1, GLONASS G1, BeiDou B1, QZSS, SBAS, ready for Galileo E1
- Processing unit: Intel Edison - dual-core 500MHz
- Connectivity: I2C, UART, GPIO, TimeStamp, OTG USB, Bluetooth, Wi-Fi
- GNSS Antenna: external with MCX connector
- Very compact: 25x35mm
- Lightweight: 20gr
We are now funding the project on Indiegogo platform and early supporters can get an RTK kit with two receivers and Tallysman survey-grade antennas for just 499$.
>We flew planes with L1 RTK and RTKLIB and the resulting tracks were really smooth.
A Plane is not a quad copter or Helicopter....
Different dynamics and different vibrations...
The hardware for L2 recievers is not that much more than that for good L1 recievers, so if you buy dual freq capable hardware with L2 turned off its only a few hundred $, but if you turn on the L2 its at least $1500 more for the "turn on" code. When enough of the GPS sats have been replaced so that L2C is widely available I expect the price of L2 receivers to plummet. (Presently 15 sats send l2c, need to get to 24 before its considered operational)
@Nikola Rabchevsky
Antenna model is TW4721.
@Thorsten
- BT and WiFi can be switched off.
- Weight of the antenna is 50g.
- In the field outside of the city the lock usually takes a few minutes.
We didn't include the telemetry with the kit as some users may prefer to use 3G modems or have special radio requirements.
Hi all,
some questions:
- can BT and WiFi be switched off?
- what is the weight of the Tallysman antenna?
- what is the (average) time for a lock?
I assume an additional telemetry set is required as well.
Thanks and best regards,
Thorsten
Which model Tallysman antenna are you using for this?
@Pbreed
Unfortunately, price for L2 receivers is too high.
fair enough scott
Guys, With all due respect, this discussion is inappropriate for diydrones.com.
How is the swift navigation RTK GPS working out?
Real easy to do L1 RTK on something that is not dynamic, much harder to not have cycle slips on a vibrating moving platform. Until one of these low cost units includes L2, its not going to work well in a hi vibration Quadcopter environment.
@johnkowalsky
It probably doesn't matter if the missile will miss a couple of meters.
