Redesigning multirotor ESC's
3689622049?profile=original
It's been quiet on my front, but that was because I was redesigning ESC's (for multirotors and AP's).
Most of the ESC's for multirotor use the SimonK firmware on a relatively simple Atmel microcontroller. There's a single control wire running from the autopilot to the ESC, which is a signal proportionally dictates how long the mosfets are left open and as such command the torque on the motors.
And that's pretty much all there is to an ESC... No signal/wire coming back to tell the autopilot how that particular motor is doing or what the rpm or current is, it's just a "command wire". That sounds a bit antiquated for 2014.
So this picture is of an ESC dev board I first started on, here using the Allegro A4960 chip for simplicity. Shipping to Brazil takes time, so before it arrived the design already morphed into something new, so that's why the board looks unused. Both the MCU and driver chip changed on the newest development board version and I introduced testing points for oscilloscope readings; this project is about to get serious!
What are the features that I think an ESC for a modern multirotor should have?
1. Send the rpm back to the AP; for logging. I see people posting logs to request help figuring out what went wrong, but the log only states the "pwm out" for each motor, which is in no way a guarantee that the motor actually did that. So we need some feedback that states what the motor was actually doing, not what it was commanded to do.
2. Overload detection; the ESC's know what the current is and warn for overload situations.
3. Current & velocity control; neither current nor rpm is actively controlled as a proportional measure to the input PWM signal. So the control loop for the AP spans the IMU, motors, ESC and props, which is a large loop with lots of variables. This ESC will run one or two 'inner loops' and become responsible for achieving either torque or lift and run at a much higher frequency than 500Hz. What you get is that some variables no longer impact the control loop of the AP directly, which should make the vehicle more stable and likely more responsive.
4. Field Oriented Control; The flyback diodes next to mosfets typically burn energy in trapezoidal drive implementations, which  increases the heat on those mosfets. This happens because the mosfets close suddenly. The motor coil wants to resist that change, so you have a current that has nowhere to go except through that diode. In sinusoidal control, there's always one mosfet open for any coil, so the current always has somewhere to go, which means the flyback diodes won't get used, so you don't lose the heat.
5. FOC; better efficiency, because the current is always perpendicular to the magnetic field. This may come at the cost of max. torque (related to motor inductance and then only about 5%).
6. FOC; lower torque ripple (1/2-1/3) vs. trapezoidal drive, so hopefully less vibrations, less whistling.
7. Send current readings back to the AP; another opportunity for precisely logging what goes on near the motors. This could be helpful to detect ESC/motor/prop health (bad bearings, prop drag, etc)
8. Configuration; the AP can reconfigure ESC's prior to flight or when in maintenance to tune it for a specific motor.
9. Motor monitoring; if the motor stopped, shorted or the mosfets misbehaved, the ESC can shut down immediately and advise the AP. The AP can then take additional action.
10. Opportunities for automated ESC tuning specific to the motor/prop in use.
The way I see this ESC make a difference is when abnormal situations occur. The current AP's cannot be informed of failure, so it would simply send a signal to "run faster", which, guaranteed, has a disastrous effect to mosfet or motor and could therefore worsen the situation. Soon as the AP is informed something is wrong, it could sound an alarm, activate a chute, disable the counter motor... you suddenly have options!
To spur innovation in this area, I'm considering to setup a kickstarter and actually manufacture around 1.000 or so at a professional PCB house. Aren't these features indispensable for an ESC made in 2014? Would you back it?
  • +1 interested. Any Kickstarter project so far?
  • And here we go... The ESC in action. Grinding noise to be taken care of, but inbetween you how silent the motor functions. Next steps are to look at voltage waveforms, check current consumption at specific rpm's vs. conventional ESC's and work on responsive rpm/torque control.
  • Vector control implementations are pretty hard to implement, especially on processors where there's a lot of things going on at the same time. I decided on making a simulation package where I could verify the algorithm through a simulator first.
    This simulator is available on github: https://github.com/gtoonstra/bldc-sim
    Video demonstrating the results:
    gtoonstra/bldc-sim
    A simulator written in python with some basic diagramming functions for BLDC motor control analysis - gtoonstra/bldc-sim
  • Jure: That IC is what I ended up using now I think, which then would also allow voltages up to 12S. I have 4W shunts and 0.004 to improve measurement results, because the voltage over the shunt at 20A is only 20mV.
    NPQ: 20A =~ 0.4W . And indeed, the footprint of the shunts are relatively large compared to other components.
    The board dimensions of the newest board are 75mmx18mm, as the intention is to install these on normal size quads, preferably inside the arms outside of view.
  • The easiest method to measure current is to use a shunt, which usually ends up being a simple resistor, or for the adventurous types a carefully calculated length of PCB trace. Two of those in parallel to measure the currents on two phases. The total current through all phases is always 0, so you can calculate the third. CAN is getting more common as time goes along, the uavcan project is an opensource project that's quite far advanced and it makes sense to follow a common pattern, so we don't end up with hardwares only capable to work on one single platform. The px4esc is another ESC that should be capable of feeding back this kind of information, there's a video where you can see it in action.
  • Tim, most hardware is not compatible exactly because it can't communicate data back to the AP. For communication, I think it's best to use CAN for a couple of reasons; it handles the bitrate, doesn't need to share a common ground with the AP and has an addressing scheme. For can you'd need a transceiver chip or get a cpu that has this built in.
    If FOC is to be used, there need to be at least two current sensors measuring the current through 2 phases.
    I've gone through this devboard and two prototypes in the meantime and have now purchased six esc's for some more serious testing. No plans to opensource this at the moment.
  • mikrocopters ESC, sends back RPM and also temperature of the motors. Info from a couple of sensors to send back to the autopilot would be great to improve reliability.
  • 3701862367?profile=originalHere is a block drawing I made I think this would be good as a stick so that it will fit in thin places, also the way the power is routed, there can be a large amount of capacitors along the side wihch will be away from the heat source and not obstructing a heat sink also. If the design is not final this might be an inspiration or not.
    I saw ESC32 but did not think it was a good design because no capacitor space, akward shape, and fets on both sides is a great idea but don't think sinks on both sides like that...
  • I will surely buy a kit. Go on
  • Yesssssssssssssssss
