After arriving in Texas, I've talked to several land owners who complain about feral hogs damaging their property. I had a solution that would incorporate thermal imaging with a sUAS platform to track hog movement and patterns during the day and at night. While doing research I came across this little baby, the M1D Micro PTZ Gimbal.
I was very surprised at the size, weight, and resolution of this camera. It uses a FLIR thermal imaging camera that are available in three resolutions, 120x140 being the lowest @ $3900 and 640x480 being the highest at $9500. I was definitely expecting this to being in the upper teens or low 20's!
It has a very nice CCD camera, Hi-res thermal camera, and focusable laser incorporated in a weatherproof housing. Being 6" tall, 4.5" in diameter and weighing in around .9 kg, it seems to be a very good solution for a UAS system such as the X8 or similar platform.
The only issue that I have seen along with most PTZ systems in the RS-485 communication. I'm not a comms expert so I do not know if it is possible to do a P&P setup with the APM 2.5. I did come across a couple of Xtend 900 RS-485 1W modems that would allow control from a joystick or PTZ control board from the ground.
Shaun, how much is the quark? Also, what about replacement lens cost? I know you can't use standard plastic or glass because it absorbs wavelengths specific to shortwave (or is it longwave) IR.
Oh only $3,900, I misread and only saw the highest price of $9000. That is a nice price for that model.
I was thinking about using a FLIR Quark... I wonder if they're using the same camera. Using the Quark, you should be able to drop a lot of physical size and weight off this unit. It is cool looking though.
How would you be able to control RS-485 with RC gear and the Ardupilot?
@Josh, I was actually looking at that one too. For $900 more dollars you can get a CCD, laser, and PTZ zoom in weather proof housing with the M1D. But the resolution is lower. Plus the WOW factor of the camera gimbal is worth it!
I think the quality is lower, but I thought the size and cost (around $3k) would make it a possible drone camera.
http://www.amazon.com/Flir-PathFindIR-30-Hertz-Camera-334-0001-00/d...
@Chris
Some additional comments to RS485
Using RS485 beside RX and TX you need a portpin for tranceive enable. RS232 is a point to point connection, RS485 is thought for multipoint communication.
RS-485, 422, 232 are just different IEEE electrical specifications for voltages & the way that they are driven...
Meaning that all you need is a level translator break out board.
RS-485 signals are more resistant to noise than RS232 or TTL.
thats going on my xmas list
Wondering whether this would be commercially available to non-USA purchasers? If not, then what can suppliers that aren't limited by the USA export restrictions offer ?
The link below shows a nice example of FPV by FLIR.
https://www.youtube.com/watch?v=wqlptPhFmk0&list=UU7he88s5y9vM3...
MJ
