Remzibi OSD Now Available!
I'm proud to offer one of the best OSD's on the market. Specially the configuration tool and the fact that is fully customizable!I also offered because we are working together (Remzibi, HappyKill and me) to make it 100% compatible with Ardupilot, in order to display all the telemetry data on it. In the near future you will be able to have a full autopilot with IMU and OSD telemetry. Nice.. What else you need? (beside directional antenna, we are working on that too).If you see them on stock you better hurry, because they will going to be mainly out stock due to the high demand!To buy or reserve one (in case they are out of stock), go to our store. Also you will be able to see a demo video i did. I've lost the Spektrum 2.4Ghz connection and i started to dive! What i did is rise the Remote Control in order to regain control, i was lucky and i was able to bring it back to home safely and all thanks to the Remzibi compass navigation!http://store.diydrones.com/ProductDetails.asp?ProductCode=remzibi_v11
  • Here's a video using the simulator. It would work just the same with the GPS attached. You can see the waypoints changing on the OSD output.
  • Gents, you CAN use the UBlox with Remzibi's OSD. For the moment, you will have to enable NMEA strings on the UBlox to make it work. The OSD does work with the GPS from the ArduPilot. You'll need to enable GPGGA and GPRMC NMEA strings using u-center.
    I plan to use Ublox & IMU with OSD should all work with major sw mods,
  • When it is 100% compatible with ardupilot, will it still require its own gps receiver or will it be able to run off the ardupilot one?
  • Order Placed - Thanks Jordi
    -Peter
  • Awesome, I will place an order then - Thanks!
    -Peter
  • Hi Jordi,
    This OSD is compatible with u-blox?
    It could only use one gps for OSD and Ardupilot?
    I've modified the listing to reflect that it includes GPS module and serial cable.
    Peter,
    Yes it includes the GPS and serial cable for programming!
  • Jordi - does your remzibi OSD come with everything including the GPS ? doesn't say so on the store page?
    -Peter
