Two and half years ago, we started the T3 (Trust Time Trial) Contest here at DIY Drones. The idea was simple: give people a mission to accomplish, on their own field and on their own time. They would record the telemetry, and submit a KML file with the result (we "trust" that it hasn't been faked). We could then compare the result and decide who was the winner (fastest time, best pattern, etc), as if they had all been racing/competing head-to-head.
Back then, it was an accomplishment just to complete an autonomous mission with a regular plane. But we've made a lot of progress since then, and that's now possible with a multicopter or traditional helicopter, too. So it's time to relaunch the T3 Competition. And we're going to do it by returning to the first mission ever: the Figure Eight, but this time expanded to include copters.
Figure Eight Mission Rules:
- There are two categories: Fixed Wing and Rotary Wing (multicopters or traditional helis). 1st, 2nd and 3rd place awards will be given in both.
- Must complete the pattern as shown above, totally autonomously (go into auto mode before waypoint 1 and exit after you hit waypoint 1 again). The four points are arranged in a square, with 200m on a side for fixed wing aircraft and 100m on a side for rotary wing aircraft (obviously the two diagonal paths are longer). Any aircraft/autopilot allowed. It doesn't matter how close to the waypoints you get, as long as you pass on the outside of them.
- Altitude is not graded.
- Fastest time in each category to hit all points and return to 1 wins (one lap).
- The Judge will be Gary Mortimer, as always!
- Deadline is Sunday, Dec 11th, at midnight PST.
- 1st Prize in each category is a $100 gift certificate to the DIY Drones store. 2nd and 3rd prizes are $25 each.
Entries should include these three things:
- Total time, along with aircraft (and type: fixed or rotary wing) and autopilot used. A photo of the aircraft would be nice, too.
- KML file of the run (an onboard video is also encouraged, but not required)
- Screen capture of path exported to Google Earth or an equivalent, annotated with waypoints and where autonomy began and ended. Here's a sample from my first entry, way back then (original ArduPilot!):
I've just got back from the field, flying the circuit with my Twinstar. It went well, I did it in 61 seconds from first inspections of the log. Are we allowed multiple entries and have you just take our fastest? Or should I wait before submitting an entry? I bought a funjet for this contest, so if my motor arrives in time I'll hopefully be even faster :)
Colin
Well, it all went lots better first time around with aircraft, perhaps that's because aircraft AP people are better than multicopter pilots!
Cliff Gill is the only person up for it from the new crowd, well done Cliff, your entry is certainly worthy.
> Huge open surfaces on frozen lakes, soft landings everywhere
That is right no cabin fever needed. Electronics like cold.
There are subtle calms before a storm that can happen.
The only problem is the short days in the northern latitudes.
So are there any entries yet? Or are they kept under wraps until the event expires?
Will this mission alright for the T3?
#define WP_RADIUS 2 // What is the minimum distance to reach a waypoint?
#define LOITER_RADIUS 2 // How close to Loiter?
#define HOLD_CURRENT_ALT 0 // 1 = hold the current altitude, 0 = use the defined altitude to for RTL
#define ALT_TO_HOLD 5
float mission[][5] = {
{WAYPOINT,0,5,-26.6385356,28.0609971},
{WAYPOINT,0,5,-26.6375861,28.0610025},
{WAYPOINT,0,5,-26.6385308,28.0620325},
{WAYPOINT,0,5,-26.6375957,28.0620164},
{WAYPOINT,0,5,-26.6385356,28.060981},
I made a T-tail out of plastic cutting board material. But it's way too heavy. I'd like to make it out of thin sheet plastic, or fiberglass or CF, but doing the 90° joint is tricky. I can't think of any way to get a really strong joint.
I did some reading up on the HMC5883 chip, and I think it will be fine in proximity to aluminum. In fact, Honeywell even recommends using non-ferro-magnetic metal shielding to protect it from EMF.
http://www.acaltechnology.com/_files/legacy_landing/HoneywellHMC584...
I've seen it quoted elsewhere that aluminum is nearly as permeable as air.
@Robert : The Mission planner lets you download log files from APM to your PC. You will then have to use the "Recreate KLM" menu choice to create .KMZ files that you can load into Google Earth to see tracks.
That's basically where it is now, on a horizontal fin made of styrene sheet, which is on the boom 2/3rd's of the way back. But it's almost directly under the edge of the rotor disk. I would like to get it up and away as much as possible. The only good place is the tail.
@I.S. you think the aluminum plate could cause a problem with the Mag? Maybe I should find a different solution then. Any other ideas for something that is "makeable" to get the the GPS and Mag up and away from influences on a chopper? I was thinking about aluminum because I have the ability to cut and weld it easily.
4
5
6
7
8
of 9 Next
