AMAZING and THX GUYMCCALDIN ! Guy is the guy, a member of this community, who built a 3D printable APM suspension system. As you see on the hover graph above, for my large X8 octo, I get vibrations between -0.03g and +0.03g (to compare with the vibrations I got just using zeal tape +0.15g and -0.15g ).
So this is a factor x5 improvement on vibrations reduction !
Here attached a picture to show the details on how I mounted APM on this suspension system. You can get it at shapeways; I have no personal interest in shapeways, nor in the business of Guy but I think we should encourage people like him who build such perfect tools for our hobby:
here : http://www.shapeways.com/model/1388904/omnimac-apm-mount-v1-5.html?li=search-results&materialId=6
@RL, yes I am still in 3.0.1 and I did the hover in stabilize mode.
i'm using this since quite some times
http://www.goodluckbuy.com/3d-printing-white-flight-controller-driv...
cheap, same design, works fine
I'm also using this suspension system, with some rubber bits that came with an xaircraft gimbal and happened to fit. It's working great.
Hugues, ah, good point. I have not tried IMU logging. What firmware are you running?
If you just fly in Stabilize mode, I think it'll be ok. Are you still on 3.0.1?
Cheap modeling clay shaped and wrapped neatly in a piece of masking tape is an effective dampener. Just sayin, sometimes the magic elixir is in your junk box and you don't have to order anything.
The blue bulbs are extremely soft, like soft silicon gel. you can get them at hobbyking.
Do you have a log without suspension system? Something to compare to.
Do you have a flash log? I'd like to have a look at it, the Tlog isn't the best for this type of thing. I really would like to see how well the system works with the those stiff blue bulbs.
1
2
of 2 Next
