Roundup/Review of all the EasyStar clones
3689354440?profile=originalI've now had a chance to see and test virtually all the EasyStar clones out there, so this post will compare them all and make recommendations. There are a few others out there by different names, but I think most are just rebadged versions of the ones below. Bottom line: I think the HobbyKing Bixler (see below) is the best option.
3689313666?profile=original
First, the baseline: The classic Multiplex EasyStar ($72 for basic airframe, no electronics)
Pro: Lots of cockpit room, tough, flies well.
Con: Only 3 channels, comes with terrible brushed motor that must be upgraded, rudder too small and must be enlarged. Quite expensive once you add all the stuff you need. See our post on upgrading it here.
3689354440?profile=originalHobbyKing Bixler
It's available as a kit, a RTF with a 4 channel radio, and an ARF without radio. I recommend the ARF version, which is just $52. Add a 20a ESC, battery (plus battery and motor connectors), a charger, a 7ch RC radio and the APM 2 autopilot and you've got a UAV for under $500.
Some of the advantages of the Bixler, compared to the EasyStar and the other clones:
  • Ailerons
  • Big cockpit area, with tail servos on the outside
  • Decent brushless motor
  • Available in ARF form with servos installed but not a useless radio that you have to throw away
  • Inexpensive
3689385181?profile=originalThis is a comparison the Bixler cockpit (left) with the EasyStar (right). The Bixler has a bit more room.
3689385117?profile=originalDynam HawkSky ($99 with everything you need: servos, brushless motor, LiPo and charger). See our review here.
Pro: As much interior room as the EasyStar, has ailerons, comes ready to fly.
Con: Plastic motor pylon is noisy. Included FM RC system should be thrown away and replaced with proper 7+ channel digital radio.
3689385204?profile=original
Xen Phoenix ($48 for airframe with brushless motor. Servos etc not included). See our review here.
Pro: Brushless motor and ailerons
Con: Fuselage is too narrow. Not enough room for autopilot electronics. Fragile. Weird four-bladed prop.
3689385198?profile=original
Sky Surfer ($130 with everything you need: servos , brushless motor, LiPo and charger, 2.4 RC system)
Pro: Comes with digital RC system (only 4ch, however, so must be replaced for UAV use). Solid design w/ailerons
Con: Sadly, the design has changed and what appears in the product listing to be servos on the outside of the body, like the EasyStar and HawkSky, are now on the inside, taking up valuable interior room. Here's a picture of what the current cockpit is actually like:
3689385128?profile=original
3689385149?profile=original
AXN Floater ($50 with servos and brushless motor). Formerly known as the Cloud Sky
Pro: Inexpensive, solid design w/ailerons
Con: servos on inside of cockpit like SkySurfer, robbing interior of valuable room for electronics. Narrow nose makes 2200 LiPo a tight fit.3689385217?profile=original
  • I just purchased the Bixler 1400, Turnigy 9 CH Radio, and other accessories recomended by DIYDrones. Looking forward to flying it with my son. We'll add video after we have figured out the flying part of this hobby. Bought from HobbyKing. The only thing holding it up are the two T2200 Batteries that are on back order. Zzzzzzzzzzz
  • H!
    I'm finishing build of the my Bixler (rev. 1). I go with motor B2835, 2200kv inrunner, and 6x4 or 6x5 prop. About ESC, a HK 40/45A will support these setup?
    I have other KH 60A, but it's so huge!! Because, I thinking fix ESC central fuselage, foward motor.
    Some pics:
    PhotobucketPhotobucketPhotobucketPhotobucket
    Photobucket PhotobucketPhotobucketPhotobucket
    Thanks for any help.
  • As there has been no updates to this post in the last 9 months, I would like to re-open and ask the question.
    I am hoping to get an electric R/C flyer in the next couple of months and would appreciate any updated suggestions for a beginner regarding airframes and radios.  Electronics to be added at a future date.
    Thanks in advance.
    Felix: It's not available in the US yet, so we haven't been able to test it.
    @Garrett Shirley,
    Have you read this blog at all?
    The Predator is NOT in the same catagory as the EZ clones!
    The whole point of the EasyStar and its clones is survivability and stability.
    The Predator model has neither.
    It always grabs attention because it is a wellknown image with an almost romantic appeal.
    Nice looking, but a bear to fly...and not at all forgiving.
    NEITHER.IT
    @CrashingDutchman: that's quite a bit smaller than the others, and probably doesn't have the lifting capacity we need. Plus it was too ugly for me to order ;-)
  • " 4-blade propeller provides more powerful and stable performance"
    are they having a laugh !?!? the less blades, the better folks.  Big aircraft have lots because there ain't room for a giant 2 blade
  • Very nice work ! will be very usefull to all !
