Hey fellow UAV enthusiasts & professionals !
Are you working with aerial photography, image mapping, agriculture analysis, 3D modelling or something where you need to trigger your camera from a UAV platform?
We are proud to present our first product from Seagull UAV !
Seagull #MAP - which also supports the latest "system" and "compact" Sony cameras, with two trigger modes and camera on/off feature. Furthermore we have added support for multiple camera brands with 100+ supported cameras models already available !
Short demo with transmitter control:
Short tutorial on setup to use with Mission Planner:
Don't forget to use the coupon code "DIYDRONES" - and get 10% discount on your first Seagull #MAP !
The coupon code expires on August 31, 2015
Check it out at our newly opened Shop - http://SeagullUAV.com - and order yours Today
If you have any questions don't hesitate to ask – our support is ready to help - have a great day!
Best regards,
The Seagull UAV Team !
HI Rone, I have successfully connected the #MAP, but I am unable to shoot every 5 meters as the DO_CAMA_ TRIGGER command is setup to do. The number of pictures taken is 1/10 of the number of pictures I need. I have a Sony Alpha 5000 and I have the setup you suggest in your website. Do you have any suggestions?. Thanks.
Hi All
It seems there is yet another upgrade Iwant t buy the #MAP2, any comments from users?
Is there any way to send video signal to ground from SONY QX to some FPV system?
Hi everyone !
We just changed the way you pick the right #MAP and camera cable configuration for your setup!
Also added some quickguide videos by request.. :)
Remeber the 10% coupon code expires soon - come by the shop and order yours Today :)
Hi Jesus Adrian Ramos Verenzuela,
Thank You for informing about the missing T4i - it's now added to the list together also with the T6i :)
The Rebels shouldn't need any firmware scripts - they should be supported directly with the 2.5mm "Remote" Jack..
See example:
Thanks Rone - if the manual doesn't say that, it should :-)
Hi Hamish,
It's recommended to supply Pixhawks rail with 5v from a BEC / UBEC.. It can operate reliable on 3.5v yes, but 5v is recommended :)
FYI I have added a section for this on the wiki : http://planner.ardupilot.com/wiki/common-camera-shutter-triggering-...
Pixhawk nominally outputs 3.3v for the servo but your stated minimum is 3.5v. Does it work reliably at 3.5v?
Hi Romain,
To my knowledge the QX10 and 100 does not support the Sony "MULTI" usb interface.. I can't confirm this 100% since I have only tested with the QX-1 from the QX lineup...
1
2
of 2 Next
