Short Range I.R. Radar
Basically here is the site it is a short range inferred radar that could be used for a failsafe in case your uav gets close to the ground. However it is slightly bulky but that can be easily modified because it was made for parking cars. This includes a servo with an inferred transceiver or receiver and transmitter separate, i haven't really looked into it very far. If you are board and want to serf the web go to "Hackaday.com". Thats where i found the range finder and is a great place to hack if you want to.
  • MaxBotix Inc., has released the new XL-MaxSonar products. This product line should solver the problems above relate to noise and not enough acoustic output power. The XL-MaxSonar line has fully automatic real-time background calibration, much higher acoustic output power, greatly improved real-time noise rejection, centimeter resolution, longer distance range measurement, and for some models real-time analog envelope output and various analog hardware gains from 250 to 4000. These improvements result in virtually noise free distance readings for most users. The XL-MaxSonar is avaialbe in both indoor and ourdoor versions.
    Please click this linkt to view more information about the XL-MaxSonar products. http://www.maxbotix.com/uploads/Small_Industrial_Ultrasonic_Sensors...
    Best regards,
    Scott Wielenberg
    Technical Support & Sales
    of MaxBotix Inc.
    Phone: (218) 454-0766 Ext. 2
    Fax: (218) 454-0768
    Email: scott@maxbotix.com
    Web: www.maxbotix.com
    MaxBotix, MaxSonar, EZ0, EZ1, EZ2, EZ3, EZ4 and WR1 are trademarks of MaxBotix Inc.
  • yes that maybe an idea... getting some readings first and avaraging them as a reading fix... can u post your smoothing code here so that we can check with ours... i am not very good at programming and usually waste my hours writing and debugging few sentences... :) i also use nunchuck in my project and i have a working code moving 2 servos with nunchuck accelerometer at roll and pithch axes... if u want i can post it here for you...
  • i have the same sensor and planning to use it for autonomous landing assist... i did almost the same tests with u but i used raw values at analog0 of my arduino. i also added a small cylinder 1inch long to narrow the receipt angle... however my ez1 reads 0-320 raw readings.. i wrote a simple code to read the raw value and light a rgb led... val>100 green, 100>val>50 blue and val>50 red... i tested indoors only wandering around my home and had mostly consistent readings. i even tried to smooth the reading by adding a 0.1u cap between analog0 and sensor but this proved to be better first, but after some minutes the cap heats and reaings get to be erroneaus about 20 inches. i am also convinced that i can use this sensor as an assist in autonomous landing...
  • how quickly does the EX1 update the distance? I tried using Lego NXT ultrasonics a while back with my UGV but they were just simply too slow for anything usefull - so I switched to scanning IR (its an indoor vehicle) which works very well. I have been thinking of hacking one of those laser rangefinders for golfers into a ground proximity detector since I did not think US would be up to the job...
    Reto, I think you'll have trouble with the EZ-1 for this purpose. In our testing, it doesn't give reliable results on grass, ground or even carpets--basically anything other than a hard floor. I think you will find it useless outdoors. You might have better luck with the long distance one, but it's expensive and big.
  • Marcus, I just wrapped a project of using a ultrasonic sensor by maxbotics that has a 255 inch range. Works pretty well but required me to program a filter to get rid of some noise variance.
  • I'm trying to work with an ultrasonic sensor that speaks I2C.
    This should be much smaller and even have more range
    then the IR-system.
    Pro: It is independent of light and reflection -properties
    Con: ...ultrasonic and dogs. Works inly in one direction at a time
  • well i have been reading that sometimes the sound waves will bounce in different directions and give messed up results
    so i think inferred is more reliable but it is only for short range. like an emergency
  • That thing looks huge, how much does it weigh?
    I dont understand though, what does this do that a much lighter and smaller ultrasound rangefinder won't?
