SkyHunter FPV UAV Aircraft Platform - kit
42722.jpgThe first thing that came to my attention was the large bay which is suiteable, according to the product description, for batteries from 5 to 20 Amps. The large bay in combination with a wingspan of 1800 mm (70 inch) and the suggested power train allows this aircraft to carry enough gadgets to make it a great FPV aircraft.
Features:
• Tough EPO Construction
• Large Size Ideal for a Stable Flying in a Variety of Weather Conditions
• Unique Nose Mounted
• Large Camera Canopy
• Plug In 2pc Wing and Tail for Easy Transport
• Large Payload Capability
• Large CF wing and tail Tubes
Price is US$ 111.78 and available from Hobbyking
  • I don't know if is only white version, but I've bought recently a skyhunter white from cambriahobby.com, and quality of the CF tubes of boom are poor, very crappy!
    And it came cracked in the end of one tube also.
    I'm afraid to build/fly the plane with these tubes, and waiting to receive new ones that I've ordered, with better quality.
  • 100KM
    Thanks Guy.. I don't enjoy fiddling at the field to get in the air. That's why I sold my bixler2. I'm so happy with my skywalker, but always wondered about this airframe.
  • "You need at least 2 meters if you need to have onboard camera(s), OSD, Telemetry, etc...."
    what a load of rubbish... never seen a TBS Caiprainha ? 85cm...
  • And... that's the reason I've held back from these things.  I'm an old-school built up balsa and liteply airplane guy.  I've only had one foam plane, and it was horrible.
    I've looked at this thing and wondered if it would work.
    http://www.hobbyking.com/hobbyking/store/__14431__Pilatus_PC_6_EP_B...
    I should just strap a camera to the bottom of my 80" Satio powered Cub and be done with it.
  • The Hercules/wings are great platforms. But you still a lot of room to fit in a car. I wish they made a bit bigger Twinstar.
  • On your note of 2 booms, I've been looking at doing the same thing. My thought is that you could take any two basic fpv planes(like the HobbyKing axn floater) and add them to a larger airframe, maybe even a flying wing, and modify the noses with some carbon fiber rods and motor mounts. The only problem would be that you would most likely have to drop the main fuse back a bit to maintain CG, which would be difficulty to do at best.
  • Interesting.  I was looking at getting a Phantom wing, but one thing holding me back is the batteries. I have a lot of 4S 5000s I'd like to use, but I'm pretty sure they're too big for the Phantom.  This thing can use them though.
    The only problem is as Guy says, the fiddlyness of it.  I also wonder how the landing is on rough surfaces.  How well it takes it.
    I really wish somebody made an airplane with a layout like this, but twin tractor props in front of the booms, for redundancy.
