Here is a short video presentation of my Skywalker X8 UAV using 3g broadband internet for video and telemetry.
Onboard my X8 i have this ZTE MF60 3g/Wifi router which handles the communication for the APM2.5 and the Raspberry Pi model B. I didn't wanna use the Dronecell because i will place the load away from the APM2.5. I could have put a 3g USB adapter in my Raspberry Pi as well, but the Pi have more than enough to do transcoding the video-stream, so i use a Cisco Wifi USB adapter in my Pi to communicate with the 3g router and GCS.
The telemetry from my APM2.5 is sent to a Serial 2 Wifi converter which then is connected via Wifi to the 3g router. I then connect to my APM2.5 using TCP from Mission Planner.
The Raspberry Pi are using VLC Player for Linux to transcode the videostream from the Microsoft Lifecam webcamera to a resolution of 352x288 at 500kbit/s and 10 fps. If you want to use the same solution just change the hostname and port to you needs in the command below. I use Dynamic DNS (client configured in my Raspbery Pi) since mye 3g router gets a dynamic IP adress on every new connection.
Command in the Pi for starting videostream:
"sudo -u pi vlc-wrapper -I dummy -vvv v4l2:///dev/video0 :v4l2-width=352 :v4l2-height=288 :v4l2-fps=10 :sout='#transcode{vcodec=MJPG,vb=500,fps=10,scale=1,width=352,height=288,acodec=none}:std{mux=ts,access=udp{ttl=10},dst=mydyndnshostname.domain.no:2000}' :sout-all :sout-keep"
At my GCS i start VLC using this command in a .CMD file to recieve the video from the X8 and re-stream it to the Mission Planner:
"C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" udp://@226.0.1.150:2000 --sout=#transcode{vcodec=MJPG,vb=500,fps=10,scale=1,width=352,height=288,acodec=none}:duplicate{dst=http{mux=mpjpeg,dst=:8080/},dst=display} :sout-all :sout-keep
In Mission Planner you just enter "http://localhost:8080" in the "SET MJPEG Source" when right-clicking the Hud. I have a 6GB per month dataplan in my 3g router and my calculations says that this can give me more than 52 hours of videostream. My sim card is a non-firewalled APN.
For now everything is powered from a MaxAmps 11000mah LIPO This is a high capasity battery and the weight is only 825gram. My plan is to have 2 of those in my X8 for a really long range flight.
Right now i'm using a Sanwa 35mHz radio, but i waiting for my Turnigy 9XR and 433mHz modules from Hobbyking. I don't use 2.4gHz because of the 2.4gHz in my 3g router.
No you don't. For some reason it dropped my link. Here it is again.
http://www.filedropper.com/x8
@Jerry: How can i download your param file? Do i need an account on that page?
Alexey: I can make a clean SD image to share. I can also make a brief description for which parameters to change to your own needs. I will let you know when and where to download this.
hi Tommy
Could you give the SD card image of mission planner for PI?
I tried two weeks, but without success
I've been using this x8 param for about a year now, flies good.
http://www.filedropper.com/x82
I will also add an SSC-32 Servo controller to control other things via IP and 3g later. So i will let the 3g router take care of all communaction in my X8. I wil use a ser2wifi converter for this as well.
Hi
A) Yes the Pi has more than enough work to do transcoding the video. Need to overclock the Pi to "Medium" to make it able to transcode the video
B) Same reason as A)
Here is a short video of my pan/tilt in front of the X8 :)
Yes, my 3g router connects to the internet and get a dynamic ip adress. Then my RPi is updating my DynDNS hostname with the current dynamic ip. Then i use this hostname to connect to the 3g router and gets forwarded to the serial2wifi adapter and finally the APM. Like this: GCS-3grouter-ser2wifi-apm.
The video connectivity you understood right yes. DynDNS in both ends.
@Mike t: No i havn't tested with a mission yet. I need to feel safe about everything first (Servos, reciever, battery/bec etc)
@Jack C: I can use 6GB per month and only pays like 25 EUR. That's like 52 hours of video per month with this stream settings.
@SaadTiwana: The video latency is about 500ms when i run telemetry at the same time
@Nicholas: I connect to the APM2.5 using TCP. This means that i connect to the APM and not a UDP stream from the APM to my GCS.
@Biggles: Yes i have thought about that. But my goal is to use my GoPro connected to a video capture device. These days i'm testing different capture devices on my RPi with variable luck so for now it's a Microsoft webcam who does the job.
1
2
3
4
5
of 5 Next
