Some details on the iPhone 4's GPS chip
People are starting to look seriously at the iPhone 4 as a robotics controller. It's got a full IMU and otherwise looks appealing. You can get all the hardware chip and sensor specs from this excellent iFixIt teardown, but here's just one example: the GPS chip.
It's a Broadcom chip and the refresh rate is "up to 2Hz". The user-accessible data is provided by the OS so the refresh rate in practice may vary, but the hardware looks pretty promising.
  • the GPS is only up to 2 Hz. That is a bit slow refresh rate, no? For flying things anyway.
  • @jeffrey - if only that was true ;-) It remains one of the most locked down pieces of consumer electronics in history. Of course, jailbreaking and writing apps for iOS isn't so bad - you get to use their nice APIs, power management, comms, imaging etc, and technically, iOS is even a real-time operating system.
  • An iphone is just a computer running linux.. Ofcurse you can flash it and do what ever you want with it.
  • Hugo: Interesting. Anyway, an arduino will always be needed to command and get information from the actuators.
  • I doubt the built-in accelerometers, gyros, and magnetometers are any different *at all* performance-wise from the ones we hobbyists use. iOS even has a built-in sensor fusion (Kalman filter) algorithm perfectly tuned to match the sensors. I personally would guess that most hobbyists achieve worse performance (even with better sensors) due to this professionally designed, coded, and tuned fusion algorithm.
  • Well, using smartphones as GUI interfaces, data storage, long-range communication (3G, texts) and computation power (image recognition) for robots is cool. But I doubt the built-in IMU and the accelerometers are accurate-enough for robot positionning.
    I believe in the use of an arduino as an interface between the real world (sensors) and the big brain (that may be a smartphone).
    As for what smartphone will be the most used, I guess it would be an open one with usb-host support for communication.
  • It seems like you would have to hack it to make sure you can really get access to low level hardware stuff.
    Martin: why do say that? It's already used to control the Parrot AR.Drone, and Android phones as robotics controllers are now ubiquitous.
