Some recent features added to the Mission Planner
3689474146?profile=originalYou've probably noticed that Michael Oborne seems to be improving and enhancing the Mission Planner every day, judging by the frequent autoupdates. And you wouldn't be far off from the truth! We don't post a changelog with every update (it's too many to keep up with), but if you're curious, you can always see them in the repository changes lists.
Michael recently posted on some of the more significant ones on the dev list, so I thought it would be helpful to repost them here, for a wider audience:
Mission Planner 1.2.7 enhancements:
    1. added the ability to open the flight planner tab on the flight data screen. Right click the map > flight planner.
    2. changes to grid mode to add inter waypoint, waypoints, also implemented new algo, plan on keeping both for a while.
    3. added ability to specify a separate antenna tracker location. used to assume it was at home.
    4. ground alt is now shown on the altitude tape on the hud. brown overlay
    5. modified the guided mode altitude selection, it now remembers the last alt used so its just a right click and it will do it.
    6. slowly moving all flight planner option to the right click menu, to free up screen real estate, linked to 1.
    7. closer to AP and AC release will need to update the AP_Mount tab to work correctly since the last set of changes.
    8. Same as 7 for the AP_Limits
    9. There has been some work done for running the planner on Mac, there are still a few issue however.
and just a few tips
1. you can modify whats displayed on the Quick tab by double clicking the item.
2. you can change the max speed shown on the speed gauge by double clicking it.
3. you can double click the name of any tab in the config screen and it will popout, so you can use it from any of the other screens ie pids.
4. you can upload ardurover from the firmware tab with Control-R
  • Hello!
    How can send video, in "planner" tab on configuration panel option? Where and how I connect my Vtx in APM 2.0? I don't found this answers on WIKI.
    Thanks for any help.
    @peter, please check the right click menu
  • Another nice feature would be the possibility to run MP in fullscreen to utilize the hole screen.
  • I believe that there should be a menu entry or button for every function.  Right clicks are very good shortcuts, but they should not replace the more obvious and more easy-to-find methods.
    Just my 2c about UI...  I'm not a UI designer but I am a user :)
    Eagle: They're all there. Saving and loading waypoint files is done via the right-click menu:
    3692495386?profile=original
    Saving mission log files has been automatic for a long time. And loading them is right where it has always been:
    3692495406?profile=original
    Loading and saving parameters is also right where it's always been, in the Parameters list
    Check the right click menu, its still there.
  • Yes!!!  Mac version, please!
  • I´d like a way to select the code version to upload. sometime I need to reload the code but not ready to load a new one.
  • Michael, do you have preferred way to send you issues found in Planner? I have at least a few of them.
    Omar,
    you can already do that. double click the pid header on the config page.
