I got my Sony Webbie! and with the wide lense.
It's installed in the nose of my easystar, I was a little nervous if it was too heavy for the star.
The test flight went ok, although the weather was bad.
I think it's a great camera for UAV and FPV, although it is big for the Easystar.
*AV out.
*Hi res HD on the SD card.
Comment by Mike on November 9, 2009 at 4:57am
Hooks,
is that with the wide angle attachment? What is the FOV without it?
Mike
Comment by Robert Krogh (hooks) on November 9, 2009 at 5:00am
Before first landing im flying with the Wide angle..
Comment by Mike on November 9, 2009 at 5:04am
ok thanks
Comment by Bryan Cuervo on November 9, 2009 at 6:01am
Hooks,
I'm using the same camera and attaching it to the same location in my tailless. I used velcro to fix it and a thin velcro strap to make sure everything stayed put.
I didn't know you could get a wide lens as an option and I like the way you rigged a servo to it.
Bryan
Comment by Robert Krogh (hooks) on November 9, 2009 at 12:52pm
The lense are from usbfeber.com
16.99$ from HK
Comment by Daniel A on November 9, 2009 at 1:03pm
Hi Hooks,
What software are you using at the end to stitch together the motion compensated frames? Something like Deshaker?
Cheers,
D.
Comment by Robert Krogh (hooks) on November 9, 2009 at 1:09pm
For good video reception I use the EZ tracking antenna with ground station.
It uses the Right audio signal to send GPS info from the EZosd.
I'm not a salesman, but it's just - real Plug and Play. Great OSD + Tracking antenna + Ground Station using Google earth.
I know this Ez from Immersion is no news, but I like the very easy and simple way off using hard technology.
Maybe it has some interest from the Arduteam. No need of extra transmitter to send info from GPS - just like the Xbee.
The sound on the video are just to show the signal comming from the transmitter. (awful sound)
Comment by Robert Krogh (hooks) on November 9, 2009 at 2:20pm
Daniel A.
The name of the software are sony PMB (picture motion browser) v 4.1.00 I came with the webbie. I'm not sure it's any good.
Comment by Scott James on November 9, 2009 at 6:34pm
That's great!
I got my wide angle and fish eye lens today.
I'm going to hook up my webbie like this...
Comment by Jordi Muñoz on November 10, 2009 at 4:18pm
I have been using that camera for about 6 months and is very good. But i had vibration problems using HD 1080, whem recording video, VGA works incredible well. The live video is great too! Also if you want i can mod your webbie to take pictures a video using your radio control and disable the image rotation when you rotate the camera up and down... .
Comment
