For those interested, I found one of the papers that Alex mentioned. HERE .
It's a pretty good description of previous feats, including flying through windows. It's not the nano-quads, but the full sized ones. There's a good description of the quad itself in the section, "1.5 Experiment Design and Implementation Details".
Thanks for the info Alex. Look forward to more.Will be interested in how you guys are accounting for hover-drift and the IMU setup. The forces on faster [synch-ed] manuevers make more sense to solve first (mainly more desirable to solve/handle than drift) such that it made sense your experiment would succeed.
Also, are the vehicle commands executed from the ground station, or, are they preloaded CSVs onboard and just triggered?
Control stuff was developed mostly by Daniel Mellinger (look up his papers on trajectory generation on google scholar). Orientation is done onboard. Vicon does track orientation, but it's too slow for really aggressive stuff (100Hz is too slow!). We use Vicon only for position feedback.
Do you have any papers, describing the flight control methods that you're using? Is the craft orientation all done using the image recognition, using the Vicon?
- We've developed the software and hardware from scratch.
- We try to push the platforms to their limit in controlled environments in order to see what may be possible without precise motion tracking by cameras
Now we know why American economy isn't doing very well, bombs are very costly things ;), so many countries, even on small average spend it would add up, kind of explains why the lobbying power of military-industrial complex is as powerful as banking ;)
IR cameras are the first step. The system must be first characterized in order to know its capabilities.. Stay tuned in ;)
https://fling.seas.upenn.edu/~dmel/wiki/index.php?n=Main.Publications
check Minimum Snap Trajectory Generation and Control for Quadrotors
We'll provide more info very soon. Please hang on :)
Hey Alex, very impressive work, indeed.
To answer some of your questions:
- Stay tuned for more details soon ...
Alex Kushleyev
A bit off topic, with the war talk, unless you can link it to small quads. ;-)
Hey guys, can you take this stuff to the Rant and Rave thread?
1
2
3
of 3 Next
