Taking the New Bird Out for Turkey Day
Hiking Sweeney Ridge on Thanksgiving morning was a perfect time for testing out my newly completed quadcopter.
This spot in the mountains, 1200 feet over SFO and the Pacific ocean, seemed like a perfect place to test out my newly completed quadcopter and my newly acquired piloting skills. I've been spending hours and hours flying collective pitch helis in a simulator using a PPM-to-USB joystick adapter I built – trying to get past the heading-aligned flying I've done for years now. It's also the first outdoor flight of my new custom quadcopter and my first time with the KK2.0 flight controller too.
3689487895?profile=original
Parts list:
The frame is all carbon fiber: about 1.5 meters of 6mm square tube and two 60x60mm 0.5mm sheets epoxied together. The motors are mounted directly to the motors using zip ties (with hot-glue holding them from sliding off).
The battery mounts via velcro underneath (with an extra strap just to be safe). I built a modular camera attachment with some spare plastic pieces I had lying around from some cheap ikea curtain mounts. That's right.
3689487948?profile=original3689488023?profile=original3689487822?profile=original
Built / Design process
I picked out these motors for their weight/size/power and figured I could work around their idiotic peculiar design. I sketched out the design, computer modeled the specific dimensions I wanted, then measured everything out to a piece of cardboard (an insert from a new pack of t-shirts). Using foam tape to hold the carbon beams in place I used plastic weld epoxy to sandwich the plates on the top then the bottom.
3689487972?profile=original 3689488043?profile=original3689487999?profile=original
I'm running with my 3 year old 10A plush ESCs that I reflashed to run tgy firmware. I built a friction-contact programmer out of some wire, a clamp, hot glue, and a servo horn.  I wouldn't actually recommend doing this anymore, hobbyking sells these now (480Hz update rate out of the box) although I haven't tried them.
  • T3
    Cool build, neat video. Thanks for sharing!
