I spent some time on the software for the ground control station lately and did some telemetry flights with my UAV Flying Wing.Nothing special but I thought I'll post this anyway so people know that I'm still alive. The software is a work in progress and I'll post some information about it later.Ground control station- XBee Pro (RP-SMA)- Duck Antenna (RP-SMA)- XBee USB adapterIn flight- Arduino Mega microcontroller- DIY shield for the Arduino- GPS module EM-406A- XBee Pro with wire antenna- XBee Pro adapterThe XBee modules I'm using for the tests are surprisingly easy to setup and use. They act just like a regular serial interface and I'm using my SimpleSerialization library for the Arduino to transfer the telemetry data.
Jaron, 48'' and 60'' are the most common sizes for wings. i would prefer 60'', Foam/balsa hybrid, and a fuselage with removable hot-wire foam cut wings. Build time would be incredibly fast. Build the fuselage, glue carbon spar, and install gear,fly. The foam core's could be ordered for those that do not know how to for less than $20-30 shipped.
Gary, winter has hit me here in Switzerland, so if South Africa is where you are flying during the winter time, I'll build it for you there.
Curt, I'm currently "thinking" of a predecessor and have done some calculations and rough drawings. It'll have more wing span but I haven't decided how much yet.
Heres more on Bryan's wing.
http://diydrones.com/profiles/blogs/flight-tests-with-the-uav
It'll be interesting to see the difference in flight characteristics between your flying wing and the KFm airfoiled UAV Flying Wing.
Just wanted to let you know you were the original inspiration for my tailless design. I've also learned a lot using your UAVplayground
Thanks!!
