My recent bout if insomnia resulted in the above. Should be a lot of fun for FPV. The roll bars and added boom support as I am going to try a larger from rotor distance and maybe a differnt size motor all together. Front to back, recently spoke to a friend and asked why not use a pillow block on the front, add a servo and tilt rotor here we come.
The wires were deliberate at the end but then evolved into the fire breathing dragon. The VR Brain micro is the FC. So far I am impressed with the compactness of the design, I spent a ton of time on wire management.
There is a Twin Adjustable voltage regulator PDB, on set to the 5V and the other to 12V. The LEDs are integrated from the FC for notifications, and will get some video of that in action hopfeuly.
If anyone is interested in the first run of this model or frame type I am keeping a list to contact when they will be ready in 9 days
Thank you! Mathieu
Bravo!
I moved the GPS off the pole, worked better during FPV flights, will have more footage uploaded today., the NEO 7M Ublox did not seem to have any interference issues.
lol, it is funny you mention the ships in bottles as I was looking to use fishing line to pull some things in place and post tension everything.
Here is a test flight video to see what the watt draw over time would be. I do not have a current monitor on board.
Hi Buddy, I admire your work. Very cool indeed. Do you perhaps build ships in bottles as well:)
awesome rail
Setup and getting avg. 382 Mah spent on load per Min
Sunny Sky 2204 2300kv
12A Quadrysteria ESC
6"x4.5 props
2700Mah Zippy compact 3s
Gopro Hero Black 3+
Sony 600 TVL
Twin Variable Bec, mini PDB
Integrated LEDs leads to the VR Brain Micro (GPS "Yellow", ARM "Green")
915 Mhz, 3DR Telemetry
Minim OSD
That's pretty cool. What is the exact setup you are using? Motors, props, batteries, etc? Looks fun to fly.
1
2
of 2 Next
