Sky Eye-T50 is a 3-axis high stabilized gimbal with thermal camera.The thermal camera is with 640*480 resolution,25HZ,allows you to detect targets in the night or low visibile conditions,and provides you with priceless information.Furthere more,the thermal camera comes with a 50mm lens,which will enable you to get very clear thermal image even you are 500 meters away from the target.High-performance 3-axis gimbal is developed based on FOC(field-oriented control) technology,which will give you crystal clear video footage.
Sky Eye-T50 is using the most advanced thermal tracking technology,with which you will be able to track the target very easily.How it works: put the object you want to track in the screen,move the cursor to the object and lock it via controller,and then the camera will track it automatically.
Another big feature for Sky Eye-T50 is that the gimbal will geotag the video streaming and photos,also gimbal Yaw/Pitch angle,height,time information will be displayed on camera OSD,this is really important when you are conducting missions like rescue and search.
Sky Eye-T50 comes with an amazing advantage that the gimbal can not only be controlled via PWM signal,but also serial command.Also gimbal status(like Yaw/Pitch/Roll angle,zoom position etc) can be obtained by sending serial command to the gimbal via its serial port,which is really useful for precise gimbal control and system integration.
Sky Eye-T50 provides an outstanding wiring hub design for RC receiver and video output port,which makes wiring pretty easily.Also the gimbal offers 2 smart speed modes:FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick.LOW speed mode is used for large zoom range,will enable you to target the object more accurately.
Features
1)800grams,light weight
2)Thermal camera:640*480 resolution,25HZ,50mm lens
3)Digital zoom:1X,2X,4X,8X
4)HDMI and Ethernet video out
5)Auto object tracking
6)Geotagging
7)PWM control and serial command control
8)Convenient wiring hub for RC receiver and video output
9)3-aixs high stabilized gimbal system
10)Adjustable control speed: SLOW speed for large zoom range,accurate.FAST speed for small zoom range,sensitive and quick.
11)One key back to center
Product link:http://www.yangdaonline.com/sky-eye-t50-3-axis-gimbal-for-thermal-camera-with-50mm-lens/
Product Photos
