This is a lunchtime sketch: will make this quick.
Two independent brushed (thinking weight and cost here) motors directly drive counter-rotating rotors.
I used 4x Blue Arrow S0251 micro servos as a template only, for this concept, to drive the articulating rotors for pitch and yaw control.
Cons to this idea? Row will be controlled by variable motor speed control--I wonder if spinning up one motor to roll the craft will cause undesired gyroscopic affects (hence my first concept using bell-hiller). Two motors also will double probability of motor failure mid-flight. I need to use beefier servos for this design, which will add weight and draw more amps.
Pros: less moving parts, simpler and possibly stronger design.
hmm. This concept is 11" wide rotor tip to rotor tip.
My inspiration came from the movie Avatar (the physics are vaguely rooted in reality), but my design inspiration was copied from V-22 Osprey and other successful RC VTOL's.
I will be doing some math, but i believe that if I shrink my blade length (and mass), the design will look (and be) more feasible. Also, in this configuration, the rotors will rarely be pitched in the same direction. They will be rolled inwards and outwards (in relation to the center plane) to control pitch of the craft. They will be differentially pitched forward and backwards to control yaw. Rotor speed will control roll. Only to control forward/backward flight will the rotors need to be pitched in the same direction, and this movement will be very small. However I agree with you Alex, I may need to incorporate some other stabilization to encourage the body of the airframe to resist the collective pitching of the motors. This would probably be in the form of either
a) a third rotor - as you and others have suggested
b) a horizontal tail - do you think that a horizontal elevator at the rear of the craft would be adequate?? I think it might be....
I think that as you mentioned the gyroscopic effects of tilting the rotors will be a concern, for sure it will be a major factor if you tilt both of the rotors forwards/back as you might find the body will rotate instead of the rotors as they are relatively large compared to body, and the body does not have any mass beyond the rotation axis (not sure if i explain this very well) I would recommend to just go for a tricopter configuration, or a coaxial config (one rotor above the other).. just my 2cents :-)
jack- My previous post uses twin rotors on a single motor, basically reaping the benefits of quad/tricopter development, adding inherent stability, and adding a more sophisticated flight control program to keep it stable. However I do not know if it is possible to run two rotors off the same motor, AND make it flybarless.
ryan- I will not buy that (too big :-/) , but I will be looking at that in depth. Thank you for the link! I am trying to make this as small as possible, so it will be a "safe" indoor UAV (I'll add rotor guards/ducts later).
I really appreciate the thoughts. I have not discounted anything that you guys have said. I'll think this all through and post again when I make some forward progress.
http://www.tech-mp.com/Twinn_Rexx_support.htm
