    Yep TGY is darn good radio for the price.. I have been having one now about 6 months and only complain I have is about those switches but then again.. I they bother too much you can always go and by new and a bit better switches with few $$ and replace them..
    I have not replaced those yet. Mainly it's the nut and bad thread on few switches.
    After I got mine, i have not used my Futte 7CAP at all :)
  • I odered one last night. I have been using my old 72MHz Fatubu T6XH for my quad. Can't wait to get the proper # of channels. Let's see how long it takes to come in.
    Thanks for the heads up!
  • Awasome! Ordered one. Gonna put on it a corona dsss and 35mhz transmitters. With selectable switch of course.
  • Good review:
    http://translate.google.com/translate?hl=en&sl=fr&tl=en&...
    bungymania.com - This website is for sale! - quest 50 cmpro twinstar II easystar easyglider…
    This website is for sale! bungymania.com is your first and best source for all of the information you’re looking for. From general topics to more of…
  • I love thier backlights for the 9x
    http://www.smartieparts.com/shop/bmz_cache/e/e88e575224c0f3ccbeb89f...
  • There is an extensive DIY solution out there with 2s lipo, however to get true benefit of that you must upgrade the code.
    http://rcmodelreviews.com/tendollarbattery.shtml
    although I used the rechargeble 8xAA pack for quite a long time before going to lipo, I use a 3s as all my chargers are that way... ;)
    A 2400mAH Lithium Transmitter Battery For Just $10
    Fit a 2400mAH battery to your 2.4GHz transmitter for $10
  • What is the best battery to use with this transmitter, NiMH's or a LIPO, if LIPO which is the correct one that fits.  How do users re-charge the LIPO, does it have to be removed, in case of NiMHs can they be charged while installed in the case?
    Got one from the previous batch to play with. It's the perfect hack radio.
    Alternative open source firmware:
    http://code.google.com/p/th9x/
  • I got an Eurgle, that is the same radio, only change is the brand sticker... but when you compare this radio and the posibillities of re-flashing it with new Firmware, adding options, a bunch of good people writing new codes basically you finish with a better product, a lot of support from the guys on RCG on this radio!
  • Here is the add on board and backlight
    40USD
    http://www.smartieparts.com/shop/index.php?main_page=product_info&a...
    Write up on the upgrade:
    http://www.rcgroups.com/forums/showthread.php?t=1338412#post16549680
    Frsky telemetry modules (the turnigy 9x is JR module compatible)
    http://www.himodel.com/radios/FrSky_Two-way_2.4G_JR_Compatible_Radi...
    Total for the setup
    turnigy 9x ~60 + shipping
    proggy and backlight ~40 + shipping
    FrSky modules ~75 + shipping
    175 total, not bad at all for an 8ch radio
    even went for an upgraded antenna as well :)
    http://www.himodel.com/radios/5db_Antenna_for_2.4G_RF_Module_19.5cm...
    9x Solderless Programmer Board Rev 2.4 - $36.00 : SmartieParts.com
    SmartieParts.com 9x Solderless Programmer Board Rev 2.4 - Product Discontinued. This bolt-on programmer board gives you an easy and solderless method…
