New Task Force to Develop Recommendations by November 20
WASHINGTON – U.S. Transportation Secretary Anthony Foxx and FAA Administrator Michael Huerta today announced the creation of a task force to develop recommendations for a registration process for Unmanned Aircraft Systems (UAS).
The task force will be composed of 25 to 30 diverse representatives from the UAS and manned aviation industries, the federal government, and other stakeholders. The group will advise the Department on which aircraft should be exempt from registration due to a low safety risk, including toys and certain other small UAS.
The task force also will explore options for a streamlined system that would make registration less burdensome for commercial UAS operators. The task force may make additional safety recommendations as it deems appropriate. Secretary Foxx directed the group to deliver its report by Nov. 20.
“Registering unmanned aircraft will help build a culture of accountability and responsibility, especially with new users who have no experience operating in the U.S. aviation system,” Foxx said.
“It will help protect public safety in the air and on the ground.” Every day, the FAA receives reports of potentially unsafe UAS operations. Pilot sightings of UAS doubled between 2014 and 2015.
The reports ranged from incidents at major sporting events and flights near manned aircraft, to interference with wildfire operations.
“These reports signal a troubling trend,” Huerta said.
“Registration will help make sure that operators know the rules and remain accountable to the public for flying their unmanned aircraft responsibly. When they don’t fly safely, they’ll know there will be consequences.”
While the task force does its work, the FAA will continue its aggressive education and outreach efforts, including the “Know Before You Fly” campaign and “No Drone Zone” initiatives with the nation’s busiest airports.
The agency also will continue to take strong enforcement action against egregious violators. At the same time, it will continue working with stakeholders to improve safety to ensure further integration and innovation in this promising segment of aviation.
Secretary Foxx was joined by representatives from the following stakeholder groups:
The Association for Unmanned Vehicle Systems International Academy of Model Aircraft Air Line Pilots Association American Association of Airport Executives Helicopter Association International PrecisionHawk AirMap/ Small UAV Coalition Consumer Electronics Association
Really?, Breitbart data?
I'm out.
Isn't it ironic that this government needs 'emergency regulations' to stop the so-called out-of-control drone industry responsible for ZERO deaths in the United States! That's correct. There is not ONE documented case of a single death caused by a drone.
Yet here are the statistics on deaths by illegal immigrants: (source US government stats, from http://www.breitbart.com/big-journalism/2015/08/08/illegal-alien-cr...)
Hmmm... Yet this government does NOTHING to stop these crimes, and seems to think in needs to focus on flying toys! Our streets are full of blood of innocent human beings, and they DO NOTHING, and in fact they INVITE MORE criminals to cross over! The very fact that we are debating this foolishness shows just how psychotic this government has become. They are focused on TOYS, that have a history of ZERO deaths and virtually ZERO damage. This is a NON ISSUE.
The real question here is what are we going to do to reign in these bureaucrats?
Comment by Gary McCray 11 minutes agoDelete Comment
Hi Tony, then I suggest you look through the back blogs here on the DIYDrones sites to see how many and how vocal this whole thing has been over the last 2 + years and how much of what was finally hammered out was only due to our and the AMA's perseverance.
I was saying you must be ignorant of this process, because your statements clearly reflected no knowledge of the extreme preceeding history we have had with the FAA.
You are clearly coming in now Tabla Raza and thinking how rational all this seems.
If they were proceed ing rationally, they would be registering pilots with a common ID number to be affixed to all their aircraft and for a sub $10.00 fee, that would make sense, be a lot more enforceable and manageable, but that is not what they have chosen to do.
Also, some defining line does need to be made between harmless or nearly harmless "toys" and everything else, so far they have not even been willing to discuss that consideration and the AMA guys mention of it in the live feed of the announcement sounded not particularly hopeful.
No action that the FAA has unilaterally taken prior to now has shown much common sense, all that has been hammered into it by us, the AMA and other concerned citizens, practically over their dead body.
At this point in time it doesn't feel much different.
I would strongly encourage all of you who think this is just a reasonable action on the part of the FAA, DOT and our Government to look through all the back blogs on DIYDrones you can find on the process that has gotten us to this point.
We have participated heavily and rightly called foul to many of the FAAs attempts to "bury us" and to perceive that this time that that is not the case, is, based on all previous experience, simply not in evidence.
So the ignorance part is simple, I was (and many of us were) there every step of the way, you, clearly weren't and you are operating on information that is based on false and historically very much not supported suppositions.
@ Philip, It is my understanding that until a proper immigration, registration and permitting process is worked out all Canadian geese are to be shot on sight as they cross the border from Canada into the US.
As the permitting process is expected to take from 5 to 7 years, it is expected that the necessity will be moot by then anyway.
Best Regards,
Gary
Isn't that in oxymoron, "sensible logic"? Well at least as far as a US bureaucracy is concerned. :)
Nathaniel ~KD2DEY
"Anybody know if they will be requiring all Canadian Geese to register as well?"
They would if it changed the behavior of the geese! So the answer is "no". These decisions are driven by sensible logic, after all.
So basically Pilots in category #1 foot the bill to pay for educating everyone in categories #2 and #3. Nice....not. I don't think registration is a bad idea, I just don't think it's right to require me to register each and every aircraft separately. If education is the goal, how does that improve my education. Somehow I have a sinking feeling the DOT and FAA's idea of what constitutes a "bare minimum" cost will differ from mine.
I agree completely that something must be done. This just seems like a band aid being put on a severed artery. The problem with programs like this is they keep taking the money forever, but the level of service for the fee declines with time. It ends up just being a source of funding for other pet projects.
I'm tired of feeling helpless while someone else imposes more restrictions on my recreational activity. I play by the rules and stand by helpless as day after day others fly irresponsibly and draw unwanted attention in the media to a relative minority (though highly irresponsible) segment of the hobby.
Nathaniel ~KD2DEY
@Nathaniel - I agree that the registration cost needs to be kept very low. I expect they'll try to keep the cost to a bare minimum, since they understand and appreciate the impacts on enthusiasts like yourself.
As for your point about the pilots, there are 4 categories of pilots the rule makers talk about: 1) Responsible, 2) Irresponsible, 3) Uneducated, and 4) Malicious. This registration requirement is squarely aimed at educating the irresponsible and uneducated pilots by formally having them read and accept the rules and the penalties. In that regard, it will inform and notify, thereby making people aware of their responsibilities, and think twice before doing something stupid or dangerous.
The penalties for causing an accident by intentionally flying irresponsibly will be huge and will also include serious jail time. As a result, registration will certainly reduce the number of dangerous flights simply by getting each drone owner's full attention.
As for malicious pilots (#4), the legislators and stakeholders are fully aware that registration will have zero effect. Malicious actors are a completely different issue not addressed by this new rule. Fortunately, this is a much smaller issue since the vast majority of people are not malicious.
uhhhhhm, Gary. . . I have been flying RC for a couple decades too. I didn't get the "wipe us off the face of the Earth" memo. Just calling us "ignorant" doesn't educate us very much.
We are engineers. We are data-driven type individuals.
Listening to you guys talk about sane and reasonable regulations is interesting, but please understand, that the bulk of this DIYDrones group has just come through 2 years of the FAA literally trying to wipe us off the face of the earth.
And they have been anything but rational and the only reason we still exist is the mandate of Congress for them not to make RC models illegal, the AMA's tireless work to keep us from being plowed under and the relentless voice of our own demanding reasonable actions.
To call us over the top hysteria mongers illustrates how ignorant you are of the preceding process and of the FAAs own actions.
The FAA and DOT and many members of government for various reasons would be happy to stomp our hobby into oblivion and along with it affordable commercial UAS use as well.
Most of these reasons are not related to safety, but to insuring that the big buck government contrac UAS companies get all or almost all of the UAS business because everybody else is locked out.
This is not paranoia this is business at the mil tech government level.
I hate this ongoing hypocrisy, but it is endemic in every bit of large corporate America these days.
Only by being heard loudly and unavoidably do we have the slightest chance of not simply being plowed under.
Wake up!
Best regards,
Gary
Philip: Unfortunately, there no longer seems to be any 'experts'. The anti-science crowd seems to believe that every scientist/engineer is out to get them these days, and only their own 'common sense' prevails.
Just as in aircraft design, we will see a tiered system of FAA regulations coming out of the working group. We have the LSA light-sport certification rules (applicant showing), and have already seen more performance based criteria for the Part 23 aircraft (less than 12,500 gross). There is a higher expectation that large airliners are safer than a Cirrus single engine, and that is what the rules require.
It's also about assumed risk. I know my Kawasaki dirtbike is not designed as safe as my F-150. I don't ride my dirtbike through rush hour school zones.
We need to decide whether we want to sit at the table and help craft some realistic criteria, or we are going to sit behind computers and pout that Obama won the '08 election? . . .
1
2
3
4
5
of 9 Next
