Posted by Doug Weibel on January 13, 2010 at 11:39am
1 of my 2 Ublox modules has developed a problem. It refuses to get a fix. I am monitoring it with Ucenter and see that it is operating, it is tracking 7 or 8 satellited from inside my house, but it won't get a fix. I notice that it is getting the correct UTC time, but it cannot tell the date! I assume this is why it can't solve for a fix. I have reset the configuration and performed several cold starts. Not sure what else to try??? Any suggestions?
I'm jumping in here late, but can you tell me what minimum voltage I need to supply to the ublox5 (antenna) to get an initial fix? I'm using the GS407 from sparkfun and your little adapter board. When I power it from my FTDI cable (measured at exactly 5.00v) the gps works awesome. When I power it from my UAV (4.8v receiver battery pack) it never gets a lock, never get satellites, etc. I don't think it's a hardware issue because it works beautifully when powered from the FTDI cable, it just doesn't see satellites when powered by my UAV avionics battery. Any ideas/suggestiosn?
Well, yeap something is wrong! Six hours is more than enough i guess. A batch of GPS coming from them were "defective", they had a weak antenna... We tested every unit before shipping, but in some point they failed.
The incoming devices are fixed now, but this ones i have to send them back to the factor( they will repair it for you)....
IF anybody have a defective uBlox units, send it some and i will send it to the factory for a FREE repair...
Hi Jordi, thank you for the response. I did what you menioned and after several minutes I've got nothing showing satellites or any GPS fix.
Please note below my u-center screen.
That is just telling the messages is outputting. Press F9 -> UBX - >NAV - >SVINFO. make right click on SVINFO and click on Enable Message.... THen you will know how many sats you are viewing.
If you want to see a graph (better) go and click on the tab "View" --> Docking Window --> Satellite View.. That will open a windows that will show you the SVINFO visually...
If you don't see any bar after 30 seconds... Let me know pelase
Hi Jordi, I think I've got a bad ublox from you... I can connect to the device via the FTDI cable directly connected to the little board also purchased from you, although after leaving it for more than 1 hour outside my window with sky view it do not get a lock.
Looking at the u-control system, it just shows the following messages:
Hi Jordi,
I checked today. It hasnt been mailed out yet. It's still sitting in the school's mailroom. It'll probably go out tommorow. I'll send you an email and als put in a copy of your email tha you had sent with the address etc for you to verify.
Thanks,
Curt.
PM sent!
Address, etc...
Tks,
Leonardo
Please note below (now 6hours connected and no gps fix and no bars...):
Well in that screen shot i can't see the SVINFO message is not activated.... Can you please fallow again the instructions and enable the SVINFO?
Thank you,
Leonardo
??:??:?? UBX NAV-STATUS, Size 24, 'Navigation Status'
??:??:?? UBX NAV-POSLLH, Size 36, 'Geodetic Position'
??:??:?? UBX NAV-VELNED, Size 44, 'Velocity in WGS 84'
Do you know how can I sort that out?
Thank you,
Leonardo
