Instructions for using ArduPilot 2.x in the field:
ArduPilot 2.1 and above (with Z sensor). This version of the software auto-calibrates the IR sensors. The only thing you need to do at the field is to record the "home" GPS position in EEPROM memory, which will not be erased when you reset or power down the board. To do so, follow these instructions:- Ensure that the autopilot is in manual mode (channel five toggle off) and GPS is connected
- Place a jumper cap on pins D6 and D7 (you can also connect a regular RC power switch to those pins if you want to control the autopilot from outside of the aircraft). Ensure that your aileron and elevator sticks are in the center position, and power on the board.
- The yellow status LED will blink for a few seconds as the autopilot programs the GPS for binary mode. Then the blue lock GPS will blink rapidly, which means the autopilot is waiting for GPS lock. You can now remove the jumper (or return the switch to the normal position)
- When the autopilot has established a GPS lock it will move the rudder. Note that ArduPilot puts the EM406 into binary mode, which disables the red LED on that module, so it will not blink.
- You’re now ready to fly! Press the reset button on the ArduPilot board to restart it (your calibration settings are saved in permanent memory and will not be erased).
- ArduPilot 2.0 supports two autonomous modes: waypoint and return-to-launch (RTL). If you have a three-position toggle switch or a proportional dial on your RC transmitter, the middle position is Waypoint Mode and the up (or full clockwise) position is RTL Mode. These can be changed in the software if desired. The Mode LED on the ArduPilot board will light up with it is in Waypoint Mode.
- To use fly-by-wire mode (just stabilization, like the FMA Co-Pilot), simply disconnect the GPS. ArduPilot also automatically switches into stabilazation mode if it ever loses GPS lock.
- Holding the aircraft without obscuring the thermopile sensor, point the nose at the ground. Switch the autopilot on with your RC toggle switch. The elevator will move, signaling that the sensor has been calibrated.
- You’re now ready to fly! Switch the aircraft back into manual mode for launch, and press the reset button on the ArduPilot board to restart it (your calibration settings are saved in permanent memory and will not be erased).
After upgrading tho one of my adrupilot to 2.0.the gps module dont work anymore on my
ather adrupilot 1.0.The light on the gps module burns weak and the blue light wont go on.please help.
Remco
if (Tx_Switch_Status()==0x02) //Check if we are in mode 2 (transmitter switch in middle position
current_wp=Waypoint_Switcher(current_wp,wp_distance, wp_radius); //Waypoint switcher...
wp_Mode=current_wp; //Checks if we are in Waypoint or RTL...
Dimitris
You need to mix channel 5 with channel 6. For example channel 5 will only switch between manual/auto, and channel 6 will switch between RTL/Waypoint. Or channel 5 can switch autopilot on and off, and channel 6 can switch between waypoint and fly by wire. The option is called "PMX 1"
