If you answered yes to both of those questions, then this post is for you.
I've always had a special fondness for the Sony QX-1 and decided to rig up a contraption that would let me fly her with Solo. For both of you on DIYDrones who are not familiar with the QX-1, it is a light (180 g body), high resolution (20MP), endowed with a large sensor (APS-C, 15x larger than GoPro) body that receives Sony E-mount lenses (including zoom lenses), and can be controlled by an extensive WiFi API.
First, I had to learn how to control the camera via the WiFi API. Jaime Machuca, of Droidika, wrote a nice MAVLink wrapper for the QX-1 API, but I never quite could get it going on Solo. Instead, I deployed the pysony API, which I installed on a RasPi that I taped to Solo's belly. This RasPi connected to QX-1's WiFi upon boot, ingested the mjpeg QX-1 livestream, pipe it over HDMI to Solo App, and triggered the QX-1 to begin shooting. I could control all other QX-1 functions on the ground, but I didn't have an easy way to integrate those controls into Solo herself.
Next, I had to gimbal the camera. At 280g with the 20mm flat lens and a bit more with the 16-50mm Power Zoom, a brushless gimbal was probably out of the question and would have been much more difficult and expensive to build up. Because I was mostly interested in stills, I didn't particularly care about smooth video, but rather wanted a horizontal horizon and the ability to tilt the camera. I selected the RC Timer CM102, which had no problem stabilizing the camera reasonably well and holding the desired pitch.
These two pieces combined succeeded into turning Solo into a reasonable, but kludgy solution to capture truly professional aerial images for either general consumption or the generation of high quality maps or models. However, while this project is functional, it is incomplete. This feat of engineering contains no fewer than two PixHawks, six batteries, 20+ feet of cable, two companion computers, five ESCs, 10+ feet of strapping tape, and two transmitters.
I would love some additional feedback and support from the community to potentially turn this weekend project into something that any Solo owner could enjoy. I have a few full resolution images from both the QX-1 and GoPro along with a video of this thing in action (on my desk) on my blog, to help you answer these questions.
1) Is this something you would generally want?
2) Is a servo gimbal a problem? Servos will never succeed at delivering high quality video, but seem quite capable of stabilizing the camera for stills.
3) Would anyone be willing to help me integrate pysony and appropriate WiFi boot up scripts into the iMX6, eliminating the need to carry a second companion computer?
If this is not possible, what is the easiest way to connect the stream to the Tower app?
demo...
@Luke
I have a present for you... :-)
Been working on getting a script for LiveView for the Pi (using pygame rather than GTK of previous example). It outputs to console _or_ X11.
https://github.com/mungewell/sony_camera_api/blob/master/src/exampl...
At present I'm seeing stuttering, but I suspect that this is due to my specific WiFi setup.
You can not change the size of the LiveView sent from the camera (API has a call for 'L', but yet to find anything that it works on). Start the script with '-z' to zoom image full screen (at extra CPU usage) or just set the Pi to have smaller console (in '/boot/config.txt').
There is no need to carry the gimbal and a QX1 (like in the picture) so Solo handles the 76 + 216 just fine. I designed a little attachment that links it to the same connection as the static GoPro mount, and screws into the tripod mount on the camera and had it printed for $4).
@Michael Kaba
What to you have to do to set up the QX1 and get its address?
@Jermey Is the WiFI module you all were working on available for purchase?
@Luke run following script:
#!/usr/bin/python
from pysony import SonyAPI
QX_ADDR = 'http://192.168.122.1:8080' # camera address
camera = SonyAPI(QX_ADDR)
camera.actTakePicture()
it take a single shot.
@ Jeremy, thanks for the update on delivery dates. Will your module link to the SOLO's WiFi connection and then use MavLink commands to the SOLO Tx and Android Tablet, I ask as I'm curious to know if there will be any range limits?
I would like ot use your wifi board with Sony HX90V will it work with that camera when released?
1
2
3
4
of 4 Next
