New 3DR Products: Y6, X8, FPV kit, and APM 2.6
3689533873?profile=original
Announcing our new product listings for mid-summer 2013!
 _______________________________________________________________________________________
3D Robotics Y6 and X8 Multicopters - RTF and Kit
We released the Hexa-to-Y6 conversion kit a few weeks back, and now the complete Y6 DIY package and Ready-To-Fly  are available. A Y6 design is able to withstand a single motor out scenario, provides a more open and stable view for cameras, and doesn't weigh as much as a traditional Hex (because it uses less parts). It features folding arms to make ground transport a painless affair. This is our new go-to multicopter at 3DR: better performance than a quad at about the same size!
 3689533965?profile=original
If six motors aren't enough for you, there is now the X8. With the same coaxial motor design as the Y6, but with four arms. This brute is amazingly compact, it's actually smaller than our quads in the front to back dimension, due to the wide angle of the arms. This is the platform to choose for flying your heavy camera and gimbal setups. The redundant nature of this vehicle is a valuable trait when carrying expensive gear or flying over difficult terrain. This vehicle can lose a motor and remain in a stable loiter with almost no disruption .  The 3DR X8 is available ready-to-fly only at this time.
3689533943?profile=original
APM 2.6 and 3DR uBlox GPS with Compass
3689534018?profile=original
APM 2.6 is the same APM 2.5 you know and love, but with one valuable change: this revision of the board has no onboard compass, which is designed for vehicles (especially multicopters and rovers) where the compass should be placed as far from power and motor sources as possible to avoid magnetic interference. (On fixed wing aircraft it's often easier to mount APM far enough away from the motors and ESCs to avoid magnetic interference, so this is not as critical, but APM 2.6 gives more flexibility in that positioning and is a good choice for them, too). This is designed to be used with the new 3DR uBlox GPS with Compass, so that the GPS/Compass unit can be mounted further from noise sources than APM itself.
Note: APM 2.6 requires an external compass for full autonomy. If you are using APM 2.6 with a GPS module that does not have a compass sensor, you must use a stand-alone external compass. We recommend this one with this cable.
3689533900?profile=original
New GPS shown as it comes, in a nice enclosure
3689534039?profile=original
The board, inside the enclosure
You can also use the new uBlox GPS with on board magnetometer (compass) with your existing APM 2.5, To modify your board, follow the directions here.
_____________________________________________________________________________________________
FPV Package
If you have been wanting to add first-person-view (FPV) capability to your vehicle, our new FPV package gives you everything you need in one kit (including batteries). All connectors have been built in the factory and designed to give you an easy plug-and-play experience -- no soldering required! On-screen-display is provided by our MinimOSD board for real time data telemetry. This is an important safety and convenience feature for anyone flying FPV.
3689534110?profile=original
All of these items are available for order immediately.
The FPV kit is ready for shipping today.
The Y6 DIY package and APM 2.6 will ship on July 15th.
Note: RTF Y6 and X8 units will follow the normal 1-2 week turnaround. You'll find those and more on our new RTF store here: http://rtf.3drobotics.com/
  • Leszek,
    The motor to motor distance is 500mm. Clearance under the bottom plate is 135mm.
    Frame with motors props and all electronics (no battery) is 1200g.
  • Is the pricing correct? 389 includes frame, motor, esc AND apm?  so this y6 is 110 cheaper than the quad?
  • Is there any way to display the battery power of the fpv battery on the OSD?  That seems like it would be crucial information and the user guide doesn't seem to mention it.
  • Because the video camera and transmitter are analog devices, they are extremely sensitive to electrical noise.  It is much easier to use a separate battery to power these, rather than trying to clean up the noisy voltage coming from the main flight pack.
  • Regarding the fpv package:
    Why would we use a seperate battery for the onboard tx?  Assuming we fly on a 3S, can't we just hook it up to the main battery?
    Euan, I agree totally on the exorbitant shipping costs, I wanted an external magnetometer, price: $18, shipping: $39.75 - total is $57.74. You must be kidding!
    My solution: found one from another source - $7.28 including shipping! It will just take a few days longer.
  • The Y6 DIY kit looks very interesting, but unless I'm missing it, the product page doesn't have critical information like the frame weight and size, and clearance under the body. Without that, it's difficult to decide whether this is a good choice or not.
  • I see the USPS option no problem...it just costs $38! lol. I have actually email 3DR twice about shipping costs to Switzerland, with no reply. But I will do it again...
    Euan: You should have a low-cost USPS option. If you don't see that, please send your address details to feedback@3drobotics.com so they can debug why it isn't showing up for you. Most addresses/locations have that low-cost shipping option.
  • Slightly off topic - 3DR - you still need to do something about your outrageous international shipping fees. I've paid it this time, but I won't again.Shipping a 30g cable to Switzerland via airmail does not cost $38...
