Yet another Build log - Epp FPV Part 3
First of all I installed some magnets on the wings (so they can be detachable)3689409444?profile=original
Then i took out some foam and glued some Velcro to make space for my 2 5000mah batteries
3689409524?profile=original
 And finally the Gopro pan/tilt mount :)
3689409145?profile=original
  • How is did it handle with 2 5000 mAh batteries in the nose? I'm just curious since I am looking at getting this plane.
  • Thank you kirill
    Darren looks nice, I'll try it in a bit :)
  • Nicely done! I like it!
  • I lifted the white plastic and glued directly to the foam on the upper side, then glued the plastic down.
    3692216694?profile=original
  • Thank you darren :)
    If you like post some pics as it would be nice to see your idea in action . Who knows I might even borrow it :p
  • Looking good!
    I did the same with the magnets; and then I used the left over wood from the tail pieces, and sandwitched them to the trailing edge of the wing. Where the wing it sits on the wood plank by the motor. It makes it nice and level, and will be adding twist lock connectors. (I'm not fond of rubberbands) And will also be adding leading edge attach points as well.
    As this is your build; I didnt post any pics... but let me know if you do.
