I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning, can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
Ok. I can confirm running a 5 volt camera on the analog side of MOSD works.
Now that I have a screen to see, I detect a few issues that you smart guys may be able to help me with. My temp is set to F but it is reading like it is in C.
Non of the monikers for the reading appears. For example, I cannot see any A/S for Airspeed, etc. There is a read out only.
The satellite dish is flashing even after I have 3D fix, what's up with that one?
Any help appreciated,
Steven
Any idea why temp is set to degrees F but read out is clearly in C. Is there an APM setting I'm missing? I have both MP n MOSD set for imperial. I didn't see specific temp setting in MP, however.
Oh, one more thing, RSSI is working but I get %% instead %. Is this a bug or something I can correct?
Thanks,
Steven
The flashing satellite dish means your HDOP is above 2.6.
I have successfully implemented a second battery monitor in the Ardupilot (Arduplane and Arducopter). At the moment you can only set it up using a modified version of the Mission Planner software.
I have tried (and failed) to build a MinimOSD Extra version that can display the new second battery voltage. Can someone please build it for me? I have trouble with the sketch size beeing too large, which made me use a newer compiler version. My build of the MinimOSD doesn't display any values from the Ardupilot.
The change I have made in the message definitions file is in the common.xml:
<message id="1" name="SYS_STATUS">
<field type="uint16_t" name="voltage_aux_battery">Aux battery voltage, in millivolts (1 = 1 millivolt), -1: autopilot does not measure aux battery voltage</field>
... </field>
I thought it woud be easy to display the voltage (previously placed in the variable osd_vbat_B) by adding this to OSD_Panels.ino (at method panBatt_A:
if (osd_vbat_B <= 0) {
osd.printf("%c%5.2f%c", 0xbc, (double)osd_vbat_A, 0x0d);
else {
osd.printf("%c%5.2f%c %c%5.2f%c", 0xbc, (double)osd_vbat_A, 0x0d, 0xbc, (double)osd_vbat_B, 0x0d);
But no values are displayed.
I really need assistance! :)
My forks are at
Ardupilot: https://github.com/Xtreamer/ardupilot
MissionPlanner: https://github.com/Xtreamer/MissionPlanner
I have not used my MinimOSD for a loooong time. So, I want to update to latest FW, Char. Set and Config Tool. As far latest, is the "latest pre-release" seem to be working for plane or would you recommend I use the latest "stable" FW?
Another question, since I last used the MOSD, I have switched to a 5V camera. Will the MOSD work OK with just 5V going to the analog side?
Thanks so much for any help from you experts.
Steven
Gabor/Miguel... now that APM and PIXHAWK will be supporting 18 (14) channels, will you be able to modify the minimOSD-extra code to read beyond 8 channels? Is there anything stopping that today? I know that support isn't in the public release, but it appears Tridge has released it to master in support of SBUS2 so we should see it in all main releases of APM code soon unless I am misunderstanding?
I got some problem (and I'm not alone) with home altitude. It sometimes suddenly resets to zero.
Here is another one with the same problem http://diydrones.ning.com/forum/topics/ac3-1-2-baro-alt-reset-in-mi...
And here is my video
https://www.youtube.com/watch?v=FxvMxLqe7aI
Of course in APM logs all is fine and everything works, like RTL in the correct height etc.
I use latest MinimOSD-Extra_Copter_Pre-release_2.4_r726.hex and arducopter 3.1.2
Hi Vilnius,
Long time no see!
I have removed The old HA method from plane. Now OSD reads it directly from telemetry data. This means that OSD should show exactly the same values that APM is currently using.
The version you used has the old method, where OSDwas waiting for stable gps location, than sets the actual height as HA.
But that is strange still.... Hmmm... I have never had this on plane. The logic does not allowes this, even if you use the old FW, but i did see your vid... Hmmm...
Upload the attached FW.
As i mentioned above we read it from telemetry data now. Miguel have added it to copter FWalso.
Please send me feadback.
Or a videoabout it. ;)
Gábor
MinimOSD-Extra_Copter_Pre-release_2.4_r750.hex
