Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
It's the signal thats 3.3V
awesome!! nice work!
would you explain what teensy 3.1 is or give me a link ?
thanks
Its an Arm M4 https://www.pjrc.com/teensy/teensy31.html
Hi Peter, I tried this but I cant get any HDOP value in my Taranis.
Could you attach the working file.
Thanks in advance/Goran
Roger
Hi Francis,
this does not compile for me. The compiler complains that there is no ) before a numeric constant. Is there a '<<' missing in between temp and 20?
Could you maybe post your patched files?
Rolf
How are you progressing with the CPPM output.
I started a thread over at Teensy forum asking about decoding and encoding PPM streams. Paul Stoffregen jumped in and has started a library to do just that. Maybe just what you want to get that part going, worth a look at least He has written a bit about it here http://www.pjrc.com/teensy/td_libs_PulsePosition.html
The original thread i started is here http://forum.pjrc.com/threads/25265-Arduino-RC-library
Hope it is of some help to you.
Mike
The PPM encoding is easy... the problem is with using 3 serial ports ( Mavlink, S.Port and S.Bus ) at the same time and not having timing problems with the PPM data.
/Rolf
have a look at his code i think you will be surprised.
Quote from him
PulsePosition is designed for 0.02 µs accuracy (approx 24X better than most Arduino implementations using AVR Timer1) with tolerance for significant interrupt latency caused by other libraries. All output waveforms are generated by hardware timer compare and all input waveforms are read using hardware timer input capture, for extremely precise timing. Pin change interrupts, which add error due to interrupt latency, are never used.
