Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
I'm using the last version on 2.1
Clooney, I love that you guys have got together to take this project onward - its well deserving of further development IMHO as it has always been a favourite of mine for Pix->Taranis telemetry. I would be lost without the original Wolke code. I haven't yet ventured to running the new code with 3.3 and OpenTx 2.1, but will be doing as soon as i get some time. Some observations and questions I have which have never been answered prior to this collaboration which I'd be grateful if you could:
1. As I run 2 packs in parallel, my mAh readings can easily be over 10000 on the Taranis - that puts the mAh reading on the telemetry screen into 5 digits, which overwrites the 'mAh' symbol and makes that entire line unreadable as the mAh value flows into the Wh value. As I'm not interested in Wh would it be possible to add a feature where we could choose to turn off the Wh setting, by setting the BatCap Wh value to zero in the offsets screen? The idea being to have that line just for mAh - right aligned if BatCap Wh set this way?
2. As I run 2 packs, I have 2 FLVSS sensors. The script didn't work too well in the past with 2 sensors, but I believe that 2.1 introduced a fix to allow multiple sensors of the same type to be used (I have one set to ID 2 and the other set to ID 8). Would your LUA screen work with 2 FLVSS sensors used this way? And if so would I need to tweak the telem setup on the Taranis for this to work?
Love the LED control feature also - I think Pixhawk has been missing this feature so really glad you included it. Its another one for me to look into when I have more time. Thanks again guys, Paul A
hi,
to point one,
why not simple use an smaller cmin font on your script and create a new line for mah? i am at least a fan from wh. this is a real value to measure consumed ernergie. mah say absolute nothing about consumption. so it is only an "relative value display" to know what approximately happens with your battery.
i mean on 3s you measure 8000mah consumption. and if you also measure 8000mah consumption on 6s you read the same value on telemtry screen. but on 3s you consume ~88Wh and on 6s ~176Wh. this is a big difference.
/g
wolke
Just my thoughts anyway.
i know, why do you not simply change this in your lus script? you only have to remove wh on your display an than move the myh a litte bit to right. than you are fine:).
aha,
please can you create an issue with your suggestion. since i while i also contribute to clonney and stop develop on my fork.
only to know. if i create the wolkstein fork, Wh display was one of the key resource there. because in conjunction with exact single cell monitoring i wanted to make lipo monitoring so good as possible.
also to know, it is possible to calculate WH with an average voltage mostly good enough to calibrate Wh offset for luascript. if you have an hour left simple take an eye to your charger and note voltage and charging current each 3 -10 minutes also note the time. than you can calculate an good average.
i do the same with my new charger some weeks ago. i also have currently a charger without wh display. a graupner polaron. 300 bucks and no wh's. grumph:)
and since i change to opentx2.1 in conjunction to new s.port library there was the need to recalibrate my offset.
/g
wolke
In the Wiki here
https://github.com/Clooney82/MavLink_FrSkySPort/wiki/1.-Setup
Can I suggest links please for items 4 and 6. I'm trying to find the .lua script that displays the screens shown there.Thanks.
Hi
I am having trouble uploading the latest release to my T 3.1, I go to the lines to config it and I presume I am removing the '#' in front of the Teensy options? When I do this it wont compile. Sorry if I am missing something!
#include <GCS_MAVLink.h>
#include "FrSkySPort.h"
#define _MavLinkSerial Serial1 // Teensy2 = Serial1 | Pro Mini Serial
#define debugSerial Serial
#define START 1
#define MSG_RATE 10 // Hertz
#define FRSKY_PORT 4 // Teensy2 = pin 4 | Pro Mini = pin 9
#define MavLinkSerialBaud 58824 // Teensy2 = 58824 | Pro Mini = 57600
#define LEDPIN 11 // Teensy2 = pin 11 | Pro Mini = pin 13
Cheers, MIke
Thank you
