Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
Hi all,
Is anyone else not getting pitch /roll information on A3/A4 ?
Tim
I'm not getting any either. It is fixed on a value of 301. I dont think this is used in any case in the lua screen.
I'm using a FAS-100 to supervise LiPo, and it's working wonders. No more then 50 mAh offset between what's on the Taranis screen and on the charger screen after a cycle. I'm flying 9600-9750 mAh from my 10 Ah 6S packs with ease of mind all the time.
Now, I have the FAS plugged into the SPort altimeter, along with Teensy and X8R, and I think the altimeter generates a conflict with MavLink Alt. As I don't see any other wiring option, where does one disable Alt in the software ?
And more. Since the FAS is so accurate, I didn't install a regular PM, and the Pixhawk gets no battery info. Will it be possible for the Teensy to read the FAS info off the SPort bus and output the 0-3.3V the FC expects on two analog pins ?
I modify some code and integrate a touch LCD that could show the telemetry data in my ULRS CC 433 MHz middleware station.
https://github.com/liminghuang/MavLink_FrSkySPort
Has anyone tried this for connection? I'm about to order this, but would be good to know if it's any use;-)
http://www.verticalhobby.com/kauppa/en/telemetry-accessories-frsky-...
No but looks interesting. Only thing is that the description says the baud only goes to 9600 which isn't fast enough for telemetry.
Thanks for noticing that;-) I didn't check the baudrate. Then I found this. 3,50€ and It only needs TTL-to-RS232 converter.
http://www.verticalhobby.com/kauppa/advanced_search_result.php/en?k...
-K
Can this work with Turnigy 9Xr ? Similar options ?
I love this kind of HUD!
