    • Garry, I have setup several of these now and never cut that trace. 3.2 is the way forward! Works well as long as you follow the wiki guides. https://github.com/Clooney82/MavLink_FrSkySPort/wiki
      This MavLink_FrSkySPort repository is discontinued! The development is moved to athertop/MavLink_FrSkySPort. Please do not use this repo, and follow…
      • Hi all,
                  Is anyone else not getting pitch /roll information on A3/A4 ?
        Tim
        • I'm not getting any either. It is fixed on a value of 301. I dont think this is used in any case in the lua screen.
  • I'm using a FAS-100 to supervise LiPo, and it's working wonders. No more then 50 mAh offset between what's on the Taranis screen and on the charger screen after a cycle. I'm flying 9600-9750 mAh from my 10 Ah 6S packs with ease of mind all the time.
    Now, I have the FAS plugged into the SPort altimeter, along with Teensy and X8R, and I think the altimeter generates a conflict with MavLink Alt. As I don't see any other wiring option, where does one disable Alt in the software ?
    And more. Since the FAS is so accurate, I didn't install a regular PM, and the Pixhawk gets no battery info. Will it be possible for the Teensy to read the FAS info off the SPort bus and output the 0-3.3V the FC expects on two analog pins ?
  • I modify some code and integrate a touch LCD that could show the telemetry data in my ULRS CC 433 MHz middleware station.
    https://github.com/liminghuang/MavLink_FrSkySPort
    APM MavLink to FrSky S.Port converter. Contribute to liminghuang/MavLink_FrSkySPort development by creating an account on GitHub.
  • Has anyone tried this for connection? I'm about to order this, but would be good to know if it's any use;-)
    http://www.verticalhobby.com/kauppa/en/telemetry-accessories-frsky-...
    • No but looks interesting.  Only thing is that the description says the baud only goes to 9600 which isn't fast enough for telemetry.
  • Can this work with Turnigy 9Xr ? Similar options ?
  • I love this kind of HUD!
Aug 25
