APM 3.5 Instant Flip on Takeoff
Hello,
We have a quadcopter we've built using Emlid's Edge flight controller. Everything is well calibrated (according to QGroundControl) and looks fine. Whenever we attempt to takeoff, the drone flips over on its side pretty much instantly. It is a fairly large quadcopter (550mm frame).
I've attached logs below as we are pretty new to this and I'm sure people on here know more about how to diagnose the problem than we do. Any help to diagnose why this is happening would be helpful.
Whatever other information I should've provided please let me know.
Here is the copter:
3691379815?profile=original
Kind regards!
2019-03-26 13-36-19.log
2019-03-26 13-36-19.bin
  • Hello,
    Parameter reversed: could be part of QGroundControl radio calibration process.
    Motor problem: It also could be a bad ESC calibration. You can redo ESC Calibration with a receiver and a 4 in 1 plug or repeat the process for each ESC.
    Marc
  • Looks like we had a motor that wasn't performing consistently. Sometimes it would work as expected (during calibration!) but in the real world it wouldn't always work. We've got replacement motors coming and will try again then.
  • Thanks a ton for investigating. It's appreciated. I will try this and report back.
    What would cause that parameter to be reversed? I've never changed that manually.
  • There is something. In the Edge RC settings, RC2 (Pitch) is reversed. It should not. You have to reverse the Pitch channel of your RC Tx. You will have to redo the RC Calibration after changing your RC Tx settings.
    • RC1_MIN
      985
    • RC1_TRIM
      1501
    • RC1_MAX
      2009
    • RC1_REVERSED
      0
    • RC1_DZ
      20
    • RC2_MIN
      987
    • RC2_TRIM
      1498
    • RC2_MAX
      2009
    • RC2_REVERSED
      1
    • RC2_DZ
      20
    • RC3_MIN
      985
    • RC3_TRIM
      985
    • RC3_MAX
      2008
    • RC3_REVERSED
      0
    • RC3_DZ
      30
    • RC4_MIN
      987
    • RC4_TRIM
      1496
    • RC4_MAX
      2009
    • RC4_REVERSED
      0
    • RC4_DZ
      20
    There is another problem: Your RC failsafe value setting is at 985. It is also the RC3 Min value (from RC calibration). RC failsafe  could be set at 950 (if necessary, cheat with the rc3 tx trim to program the receiver failsafe). As you have to play with the RC Tx settings, adjust your RC1 to 4 endpoints  in order to be in the 1000 (1010-1050) -- 2000 (1950-1990) range instead of 985--2010.
    Before applying full take-off power, adjust enough power (in stabilise mode) and nudge roll and tilt commands to check if the copter motors follow your orders. If you are happy with the reaction, increase power until it is flying.
    Marc
  • Marc,
    Thanks for the reply. Attached is the .bin, and below is an image of the copter. The props are 12x4.5'', however the grey ones are slightly stiffer than the black ones. Could this cause a problem?
    I've made a post on the Arducopter forums, but I've refrained from doing so on the Emlid forums as I am not certain this is an issue with their flight controller... I'm more convinced the problem is between the seat and the steering wheel if you know what I mean :)
    I don't have an accurate scale but I'd estimate the takeoff weight is between 1.5-3kg. Not much on there aside from the battery, FC+GPS, PDB, and ESCs.
    https://storage.ning.com/topology/rest/1.0/file/get/3691379778?profile=original
  • Hello,
    Try to share your .bin file (downloaded from Edge). From first look at the .log file parameters, you use default parameters.
    Can you share a picture of your quadcopter (from above) and confirm Prop size and take-off weight.
    Best place to discuss is Emlid forum (Edge specific problems) or Ardupilot forum. https://discuss.ardupilot.org
    Marc
    ArduPilot Discourse
    ArduPilot Discussion Server
DIY Drones via Twitter
RT @chr1sa: After more than a year of only virtual races, @DIYRobocars returns to the newly renovated @circuitlaunch on May 22 for the resu…
Sunday
DIY Robocars via Twitter
RT @DAVGtech: And now available with LiDAR 🔥 https://twitter.com/Heavy02011/status/1381137016381964293
Sunday
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #9 - #ParkingLotNerds #thunderhillracetrack, CA Join us for the next race April 24th,…
Sunday
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Apr 7
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Apr 7
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
@GrantEMoe @circuitlaunch Update: we're doing it on Sunday (4th) at 11:00am instead
Apr 2
Laurie J. Troy liked Jasper Kueppers's profile
Apr 1
RT @chr1sa: Maybe we should have a mini @DIYRobocars race in our lower school's playground https://t.co/xLFeua1R6X
Mar 29
If anybody wants to join us for an informal outdoors hack/race we're going to be meeting at the @CircuitLaunch park… https://twitter.com/i/web/status/1375907409223249923
Mar 27
RT @SmallpixelCar: Ready to reopen, innovation has to continue. Inside/outside, LiDAR/GPS, race/delivery https://t.co/jpmvttoHEd
Mar 26
RT @DAVGtech: By far best race yet! Congratulations to the winner @Heavy02011 🥇🏆🍾👏👏👏 @diyrobocars @donkey_car @NVIDIAEmbedded https://t.co/…
Mar 20
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #8 - #ParkingLotNerds ⁦@DAVGtech⁩ ⁦@DWalmroth⁩ ⁦@OttawaAVGroup⁩ - join us tomorrow h…
Mar 20
RT @mrpollo: 11 years ago, the pxIMU was announced to the world on @DIYDrones, and it changed the life of many (mine included). The followi…
Mar 18
RT @ishcahealth: This is awesome! ☘️ @DroneDJ @DIYDrones @WorkerDrones @DroneMedia_UK @dublinaviation https://twitter.com/media_ireland/status/1372077878536462336
Mar 18
