APM and MediaTek GPS problem
OK so I have assembled the APM and oilpan, purchased the MediaTek GPS board from DIYDrones.
Everything seems to work find in test using HappyKillmore GCS  except there is no GPS data.
My config has GPS enable and I monitoring the data via the USB connected to my computer
#define GPS_PROTOCOL GPS_PROTOCOL_MTK
#define GCS_PROTOCOL            GCS_PROTOCOL_LEGACY
#define GCS_PORT 0
#define SERIAL0_BAUD        115200
Its showing a solid blue light but when I run the test i get grabage. see below
ArduPilotMega] test
Test Mode
test] gps
Hit Enter to exit.
...........test]
test] gpsraw
test] rawgps
Hit Enter to exit.
ÐÝ HþòØçª
  • Hello!
    Do you have some news for this GPS issue?
    I have a v12 GPS MTK version too and I don't succeed in logging my gps to the IMU. Blue led stops blinking on the GPS but the IMU red Led always blinks ... Can you help me please. I didn't flash my GPS.
  • Was this issue resolved? I'm getting 0 sats, 0 Fix, 0 HDOP but what looks like valid Long/Lat data even after an hour or so with APMega 1.02. I have alreday updated the GPS firmware, reset the IMU and have a GPS with battery.
    Peter
  • Hi Chris, I have the same problem , got version 1.02, with GPS_PROTOCAL_MTK16 but still no GPS sat
    I have no battery on my Mediatek GPS
    You probably have the new firmware. Select GPS_PROTOCAL_MTK16. If that doesn't work, please wait a day or two and will release new software that supports it.
